fuel problem i think ???? help
Old Dec 20, 2007 | 12:55 PM
kawategra98's Avatar
i have a 2005 ss/sc with the intense stage 3. when i am accelerating the car acts like it is not getting enough fuel it stumbles for a bit and if i floor it it stumbles for a second then takes off like a bat out of hell, is it a fuel starvation problem or what???, i have heard some people say that the 42 pound injectors are not enough that i need 60 pound injectors but 42's came with the kit.
Old Dec 20, 2007 | 12:57 PM
BOOSSTED 06's Avatar
i would definitely bump up to the 60'sa to safely run at WOT.
For your issue is it when you floor it cause it actually sounds like you might be dumping way to much fuel in right at the beginning of the curve, i could be wrong
Old Dec 20, 2007 | 01:04 PM
yea i have heard people say 60's are better, and i can gradually get on the gas and it stumbles as well, intense says this kit posts 15 psi boost, but i am getting like 17, or 18 psi so i think i do need the 60 pounders, just needed reasureing i guess, thanks
Old Dec 20, 2007 | 01:05 PM
possibly a clogged cat, im just not sure it would stumble that much
Old Dec 20, 2007 | 01:06 PM
EceSSiveMod's Avatar
or clutch slip, if ur dont have enough power going into ur gear its gonna sputter a bit till it gets up to speed
Old Dec 20, 2007 | 01:09 PM
yup thats another possibility
Old Dec 20, 2007 | 01:11 PM
no i dont think it is clutch slip, and my cat was just replaced 4 months ago under warrenty, come to think of it i only really notice it when it is real cold outside, when the temp is like 50's or 60's it dosent do it, and i read somewhere on here of someone elses doing this in cold weather i think, i dont know though
Old Dec 21, 2007 | 09:13 PM
Novajoe's Avatar
you could be getting detonation and your car is retarding timing...
You would have to run a diag to tell. Find someone with a scanner that can datastream(like EDIS or MODIS scanner) and do a run or two with it hooked up and look for knock.
If you think your injectors are too small then you can check that as well while running the diag. look for your injectors to open for longer than 80ms or so. I'd say anything under 60 is fine.
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
