Fuel Pump Fuse keeps blowing. NEED HELP
Old Dec 18, 2011 | 10:07 PM
Camerai's Avatar
So the fuel pump fuse on my 2008 Cobalt SS keeps blowing. Usually after the car is run for 15-20 minutes. I took it to the dealer and they wanted to charge me for all this testing. I put up a stink with the GM and they agreed to test it for free. Obviously I don't trust them. They couldn't find what is causing the problem and suggested they replace the fuse box. I said "no dice" and am now trying to figure out the problem myself. I could go into what I've read, but most people here know more than I do. So please if you've seen this issue before and have a solution or proposed solution I could really use the help! Thanks!
Old Dec 18, 2011 | 10:10 PM
05Slowline's Avatar
Well 08 should still be under warranty so make them fix it until they get it right...where you from in pa
Old Dec 19, 2011 | 12:06 AM
Camerai's Avatar
Also wanted to note they did swap out the Fuel Pump
Old Dec 19, 2011 | 12:17 AM
Boosted4's Avatar
Did you try checking out a wiring diagram and tracing the fuel pump circuit wiring, checking for a rubbed wire somewhere causing a ground or short?
Old Dec 19, 2011 | 12:18 AM
BlkWdoSS's Avatar
something is shorting to ground. If you can find someone that has a power probe and KNOWS how to use it. Finding the short is fairly easy. Sorry I cant be of a whole lot of help, but there are miles of wiring in this car. Since they replaced the fuel pump, I would start there and work my way forward.
l8r,
PD
Old Jan 7, 2014 | 05:23 PM
whtebalt09's Avatar
I am having this problem. If I give the car anything more than 5psi of boost it falls on its face, and blows a fuel pump fuse. then after I replace it, it has full power until it gets cold again, and repeats. Any ideas?
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
