Fuse box dead?
Old Aug 26, 2013 | 04:28 PM
casey2012's Avatar
Fuse box dead?
I have a 2006 cobalt SS. Ever since I purchased it the windows and sunroof moved slow but I thought nothing of it. Yesterday leaving work I was opening them all and a midst opening my sunroof I bumped the wheel a little and the sunroof stopped opening? I was driving home then, and noticed that the power steering warning was on, yet I still had power steering. I parked it, and went back later, and it would not start. :'( I don't think that the electronic steering is bad because it still worked. Is this a bad fuse box, or maybe a ground wire short? Any ideas would be great. Just need somewhere to start. I checked the fuse for the power steering, which I presume is labeled "EPS"? but found nothing...
Old Aug 26, 2013 | 05:06 PM
JapEatr's Avatar
South Central *********
recall on PS motor
Old Aug 26, 2013 | 05:58 PM
mrbelvedere's Avatar
wouldn't make the sunroof and such quit working post this in the problems and service section
Old Sep 9, 2013 | 09:15 PM
freeman's Avatar
I took off the fuse box once to get the the upper trans mount. When I put it back together, the car would not start. I had to take apart the fuse box again, and make sure that each of the fuse box blocks were seated with their connectors. They are like lego blocks that need to snap tightly inside the fuse box. Maybe you could check that, but be careful putting it back together ( and disconnect the battery first).
Here is a link with photos.
https://www.cobaltss.net/forums/how-...se-box-290069/
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
c_m_shooter
Sep 27, 2015 04:40 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
jmelton327
Sep 26, 2015 10:04 PM
