Gaskets
Old Dec 21, 2016 | 06:19 PM
stagewtf's Avatar
Gaskets
Regarding my last post, I have another question. Are there any gasket sets for the LSJ or not? Reason I ask is I work at my local Napa store and haven't found a set. So I thought I'd ask around here to see if any of you knew anything about a set? So, me being lazy, I don't have to buy everything separate.
Old Dec 21, 2016 | 06:39 PM
Sharkey's Avatar
most gaskets on these can be re-used. the timing cover gasket is steel with a rubber insert, the oil pan and main girdle use silicone, valve cover gasket is available through fel-pro, although id highly recommend a gm gasket here. ive never seen a full gasket set for these engines.
Old Dec 21, 2016 | 06:47 PM
stagewtf's Avatar
I haven't found one either. Good to know.
Old Dec 21, 2016 | 06:55 PM
stagewtf's Avatar
This is all I found. Crate Engine Depot head gasket kit.
Old Dec 21, 2016 | 10:58 PM
Sharkey's Avatar
what are you needing gaskets for? are you doing a complete rebuild?
Old Dec 21, 2016 | 11:17 PM
stagewtf's Avatar
Possibly. I think I'm leaking my coolant through the head so it'd be nice.
