Gasoline Smell EcoTec 2.2L
Old 10-05-2015, 06:08 PM
SnowPawsFox's Avatar
Exclamation Gasoline Smell EcoTec 2.2L
We own a 2008 Cobalt LS 2.2L. Whenever we turn off the engine, the car reeks of gasoline for a while. The car doesn't have fluids changed often, and may need an oil change. (they didn't reset the computer when they put the oil in, so it reads 30% all the time.) What's causing this? Someone told us it could be a leaking fuel injector...
UPDATE: If the car sits for a while, and you start it, it takes a long time to turn over. There are big brown spots on the pavement under where the exhaust would be when it is parked. We checked, and the injectors aren't leaky. The interior absolutely reeks of gasoline. Also, under the hood, the engine ticks a lot while it runs.
Old 10-05-2015, 07:28 PM
LsCobalt07's Avatar
It could be a rusted fuel line that is leaking. I would look under the car for gas dripping and also see if the fuel lines have excessive rust on them.
Old 10-06-2015, 11:23 AM
breds2k's Avatar
Call dealer!!!!! I just got a recall notice for leaking fuel/smell on my 07 2.2
Old 10-07-2015, 12:52 AM
EXsoccer1921's Avatar
There is a recall on it.
Old 10-09-2015, 08:58 PM
DSLaBuda's Avatar
Mine was leaking just behind the rear drivers side door where the silver heat wrap was on the line. The line looked good until it entered the line where it was completely rotted.
Old 10-11-2015, 04:09 PM
ItalianJoe1's Avatar
Broken fuel line/fuel pump carrier, take it in for a free pump if you haven't ever had it done.
rs-qt
10-24-2015 06:30 AM
rs-qt
10-05-2015 09:53 AM
SECRETARIAT
10-03-2015 11:11 PM
Trav3480
10-01-2015 08:17 PM
Delta coupe
09-30-2015 08:11 AM
Quick Reply: Gasoline Smell EcoTec 2.2L
