Gauge Issues - Fuel/ Tachometer/ Speedometer
Old Mar 11, 2009 | 09:56 AM
Kibosh3's Avatar
all three of them seem to be too far ahead - even when i shut the car off.
my fuel needle is at 1/2 and im full, once i start it up, it goes past the full mark and goes clockwise towards the E.
my tachometer is 400 rpms ahead, even when shut off
my speedometer is 10-15 km/h ahead, even when shut off.
it just started this morning- all gauges at the same time. whats the problem and whats the solution?
Old Mar 11, 2009 | 09:57 AM
revhigh18's Avatar
i dont konw how to calibrate that **** but bump for you
revhigh18's Avatar
Old Mar 11, 2009 | 11:55 AM
metroplex's Avatar
It's a common problem with certain GM cars. I remember reading about someone's speedometer reading 140 MPH just sitting in the driveway.
Old Mar 11, 2009 | 12:17 PM
06SS ALL DAY's Avatar
no it's mainly because of messing with the ECM its not just GM cars... ZZP had problems with there pcms (they use HPT also), with your HPT tune, did you calibrate it, or did you get the pcm first from an aftermarket place like ottp, intense, ZZP, etc...?
Old Mar 11, 2009 | 02:12 PM
Kibosh3's Avatar
calibrated stock ecm, been doing it for almost a year now with no issues to date
Old Mar 12, 2009 | 10:10 AM
Kibosh3's Avatar
UPDATE-
i did 3 ecu reflashes with the same tune in a row- after the third, the gauges simply reset upo start-up.
they work fine now, but im not sure it was of my own doing, or just by coincidence.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
Sep 27, 2015 08:53 PM
