Gears sticking/ not engaging
Old May 12, 2014 | 10:53 PM
Coblt ss super's Avatar
Now before anything i did try searching but got lazy. Ok heres the deal. Car will not engage into Reverse at all unless i turn the car off put it into reverse then start it. If i have the car in any gear wit clutch pedal down the car still moves. First gear just goes in when it feels like it and the rest of the gears stick and are hard to get in except maybe 5th. Now sounds to me like the pressure plate isnt fully engaging to release pressure off the clutch and flywheel. I have a spec stage 2+ with fidanza flywheel. I put new fluid in the system and bled it out and still the same. O cant seem to see if my clutch rod is bent or not. Does anyone have an answer possibly? Thanks!! I need to fix this ASAP im trading it in for a Mustang.
Old May 12, 2014 | 10:56 PM
KMO43's Avatar
I'd suggest doing another bleed. I had bit or air after I did my clutch but not the problems you have. I've heard bad things about spec maybe need a adjustable ZZP clutch rod
Old May 12, 2014 | 10:59 PM
Thats what i was thinking but cant get one anywhere
Old May 12, 2014 | 11:00 PM
KMO43's Avatar
Why cant you get one? Is ZZP sold out? I have one...
Old May 12, 2014 | 11:04 PM
ZZP is out of stock. And cant find one anywhere to buy one
Old May 12, 2014 | 11:19 PM
KMO43's Avatar
I have one. Don't know if I'd sell it
Old May 12, 2014 | 11:40 PM
Dam lol
Old May 12, 2014 | 11:43 PM
KMO43's Avatar
I see another guy looking for one never seen that before
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
Jacque8080
Sep 9, 2015 09:21 PM
