gen 1 left blinker
Old Mar 23, 2009 | 08:01 PM
bbbevans89's Avatar
gen 1 left blinker
my blinker lights up solid like its supposed to but when i turn my blinker on the green arrow is moving very quick and it stays solid and doesnt blink the right one blinks and all my rear blinkers are working. anyone know the solution.
Old Mar 23, 2009 | 08:02 PM
originaladrian's Avatar
is this a new problem? or u just installed them?
Old Mar 23, 2009 | 08:03 PM
bbbevans89's Avatar
its a new problem they have been working good for about 4 or 5 months
Old Mar 23, 2009 | 08:04 PM
check the relay
Old Mar 23, 2009 | 08:09 PM
bbbevans89's Avatar
how would i do that lol im a radio guy dont know much outside of that unless ive done it.
Old Mar 23, 2009 | 08:48 PM
DaBuzzard's Avatar
The turn signal bulb is burnt out. Replace it.
Old Mar 24, 2009 | 05:02 AM
Nighthawk243's Avatar
If you have the stock style bulbs and not LED, check the filaments. The bulbs are dual filament, so one of the filaments can fail and you may not notice (Likely its your turn signal filament that failed). Even if it still works, it could be on its way out. Sometimes a lame filament is enough to cause issues.
Old Mar 24, 2009 | 05:15 AM
loco-performance's Avatar
Might be a burnt out bulb. My mazda did that and replacing the bulb fixed it. Don't know if the cobalt has that feature tho
Old Mar 24, 2009 | 03:39 PM
bbbevans89's Avatar
ok today its working fine so in thinking the relay or the filement thing so how would i check these 2 things.
Old Mar 24, 2009 | 03:41 PM
i think its the fillament.
i forgot that cobalts do that exact thikng when the blinker is out.
there cheap buy new ones.
but if you really want to check you can take the one thats working, swap it for the broken one to see if working.
Old Mar 24, 2009 | 06:12 PM
DaBuzzard's Avatar
Bulbs are like 2 for $1.50......your bulb is bad.....replace it.
No sense wapping bulbs back and forth unless your time is worth < .50 an hour.....
Old Mar 24, 2009 | 07:59 PM
bbbevans89's Avatar
lol thanks buzzard ill get 2 and see if that helps but if that dont work i need to know were the relay is and exactly what the fillament is.
I Bought A New Bulb And Its Working Great So Problem Solved Thanks Everyone For Your Input.
Last edited by bbbevans89; Mar 24, 2009 at 07:59 PM. Reason: Automerged Doublepost
dennis69
Oct 20, 2015 04:49 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Cobalt_Daddy
Sep 27, 2015 06:59 PM
c_m_shooter
Sep 27, 2015 04:40 PM
