gen 1 left blinker
gen 1 left blinker
my blinker lights up solid like its supposed to but when i turn my blinker on the green arrow is moving very quick and it stays solid and doesnt blink the right one blinks and all my rear blinkers are working. anyone know the solution.
If you have the stock style bulbs and not LED, check the filaments. The bulbs are dual filament, so one of the filaments can fail and you may not notice (Likely its your turn signal filament that failed). Even if it still works, it could be on its way out. Sometimes a lame filament is enough to cause issues.
i think its the fillament.
i forgot that cobalts do that exact thikng when the blinker is out.
there cheap buy new ones.
but if you really want to check you can take the one thats working, swap it for the broken one to see if working.
lol thanks buzzard ill get 2 and see if that helps but if that dont work i need to know were the relay is and exactly what the fillament is.
I Bought A New Bulb And Its Working Great So Problem Solved Thanks Everyone For Your Input.
Last edited by bbbevans89; Mar 24, 2009 at 07:59 PM. Reason: Automerged Doublepost
