Gentlemen... I need some help with GM warranty...
Old Feb 27, 2010 | 02:23 AM
aterminatorz's Avatar
LOL, everything GM has put online about stage 2 fails to even mention the word spark plugs. I wonder why...
Old Feb 27, 2010 | 02:36 AM
tREBs's Avatar
what are you getting at? are you saying it is not necessary to run one step colder plugs because gm failed to mention that?
if that is the case, please do some reading on this forum.
Old Feb 27, 2010 | 02:55 AM
IhaveReturned's Avatar
I have done some reading and most people say stage 2 does not require a one step colder plug. How about you prove to us that it NEEDS a one step colder plug?
Old Feb 27, 2010 | 05:04 AM
tREBs's Avatar
The smaller pulley causes the blower to spin a lot faster creating more heat.
you don't NEED to run a one step colder plug, however your car will run a lot hotter, therefore it is recommended by many people to run a one step colder plug...
99.999% of people running stage 2 have also swapped for one step colder plugs... I wonder why.
Old Feb 27, 2010 | 05:20 AM
so the end result is your dad bought a new motor ?
and lol at some of the posts on this thread. im wondering where the logic is....
Old Feb 27, 2010 | 05:28 AM
tREBs's Avatar
unfortunatley yes, he bought a new motor...
and problem is, this forum no longer has any form of logic.
Old Feb 27, 2010 | 05:38 AM
SuperSilverSaturn's Avatar
Stage II does not require i step colder plugs...
I forgot the 3.1 pulley makes massive amounts of boost
I am on stock temp plugs on a 2.9 16lbs boost.
was on stock plugs before i got tuned with stage II tune and a 2.9 didnt have any KR till i maxed the injectors at 6500rpm
one step on stage II can cause idle problems in some cases.
Old Feb 27, 2010 | 07:11 AM
tanelk's Avatar
i keep reading how people are having problems when they put in new spark plugs, how much does gm charge to put spark plugs themselves. Not that i dont know how to do it, i just dont want to have a problem where it messes up and im screwed.
Old Feb 27, 2010 | 09:12 AM
Key word is some. Out of the thousands of spark plug changes on this forum it's only been a small number.
I could see where they could be cross threaded if not careful or inexpierenced.
Old Feb 27, 2010 | 09:32 AM
chevysssc's Avatar
read it, learn it, love it, it worked for me. call lemon law its free and wont cost u anything. i went through 5 super chargers (never beat on it during the 1.5 months either) in 1.5 months and had a water leak that came through the Onstar speaker took them 7 times to finally fix, and the water leak staind the recaros. and they only fixed it cuz i called lemon law. good luck https://www.cobaltss.net/forums/problems-service-maintenance-69/magnuson-warranty-act-205340/
o and a zex plugs tend to lean out i had em to
Old Feb 27, 2010 | 04:25 PM
  #36
tREBs's Avatar
Originally Posted by chevysssc
read it, learn it, love it, it worked for me. call lemon law its free and wont cost u anything. i went through 5 super chargers (never beat on it during the 1.5 months either) in 1.5 months and had a water leak that came through the Onstar speaker took them 7 times to finally fix, and the water leak staind the recaros. and they only fixed it cuz i called lemon law. good luck https://www.cobaltss.net/forums/showthread.php?t=205340
Only problem with this is it does not apply in Canada, otherwise I would have brought it up!
Thank you though.
Old Feb 27, 2010 | 04:30 PM
  #37
rallyracer's Avatar
Are NGK plugs pretty safe to use?
Old Feb 27, 2010 | 04:37 PM
  #38
tREBs's Avatar
I have a ton of friends who use NGK's in their balts, not problems thus far. BKR7E? or something like that.
Old Feb 27, 2010 | 05:05 PM
  #39
rallyracer's Avatar
Not sure...only number I can get of there site is:
Part No. IFR6V-10G ^ #
OE Laser Iridium
.040 gap
2007 CHEVROLET COBALT SS 2.0 L4 P FI Supercharged
Old Feb 27, 2010 | 10:30 PM
  #40
Yes, exactly. GM has world class engineers and millions of dollars, they know what they are doing.
X2. lol
lol. people on the internet told you to do it, and you did it. "People" told you to run different plugs, not GM. Hope you learned a lesson.
Old Feb 27, 2010 | 10:32 PM
  #41
time to make the popcorn, i foresee this going epic
Old Feb 27, 2010 | 10:39 PM
  #42
He ended up paying for the engine, so no matter what we will never know the exact cause. I doubt it was the plugs to tREBs but the logic behind warranty and Magnuson Moss in this thread was ridiculous.
Old Feb 28, 2010 | 04:19 AM
  #43
tREBs's Avatar
Jesus christ let it die, It is not a big deal to me either way. I don't give a **** to find threads where people have recommended one step colder plugs!
it is not a big deal to me to prove you wrong...
How about if YOU wish to search, prove me wrong?
Old Feb 28, 2010 | 10:24 AM
  #44
Haha yeah I'll let it die now. I just wish you used "Gentlemen...I need some help with my engine" as your thread title instead.
Old Feb 28, 2010 | 11:46 AM
  #45
insylem's Avatar
X2. lol
I swapped to 1 step colder plugs, because the people who tuned my car for my mods and setup (Not GM) have their own engineers, who reccomended it.
Old Feb 28, 2010 | 12:15 PM
  #46
rnjmur's Avatar
I have a few comments on this thread.
1. So many people fail at reading. He is in Canada. In Canada there is no Magnuson-Moss Act to protect them.
2. Properly torquing spark plugs requires a torque wrench. The old hand tight + 1/4 turn is FAIL. I hand tightened a spark plug then did 1/4 turn, then checked torque; it was at 10 lbs! The plugs should be torqued to 15 lbs!
3. The ZEX plugs are junk. There have been tests done that show multiple electrode spark plugs do not improve spark at all, in fact they cause less spark.
4. There have been many engine failures due to people running ZEX plugs.
5. There is no reason to run 1 step colder plugs in a stage 2 daily driver. If you drive the car hard all the time, then sure 1 step colder plugs are a good idea. But if you drive normally 95% of the time you should stick with the stock plugs. By running 1 step colder plugs on a GM stage 2 daily driver you will cause the combustion chamber temps to be too cold during normal operation causing deposit build up.
Old Feb 28, 2010 | 07:20 PM
  #47
383_Stroker's Avatar
Is everyone assuming the plug was tightened too far and hit this piston?.. because that's ridiculous
k thanks..
Old Mar 1, 2010 | 12:43 AM
  #48
rnjmur's Avatar
I don't think the plug hit the piston because it was over torqued. I think part of the plug may have broken and fallen into the combustion chamber if anything. Could have just been detonation that blew up the motor, hard to really tell without knowing more details for sure.
joeworkstoohard
How to Guide
Mar 7, 2013 02:05 AM
baddabang15
Apr 14, 2011 08:26 AM
YELLOW_REVOLUTION
Apr 30, 2008 04:16 PM
