GM employees
Old Jul 23, 2009 | 02:21 AM
HB_SS/TC's Avatar
I can probably check the piping this Saturday
Old Jul 23, 2009 | 03:39 AM
rukkee's Avatar
Originally Posted by Rissa
Or anyone who is able to, anyway you could pm or post any and every recall or tsb for the ss/tc? My car is definitely having issues now, and I'm pretty sure it's not tune related. It's just not holding boost, and last night it went up to 22, and just fell down to 10. And driving it today and last night, it just wasn't making the power it normally does. After this weekend I'm probably going to take it in to get looked at, and it would be helpful if I at least knew some common problems, searching has brought me nothing. Help a girl out! Thanks.
Service Information 2008 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Document ID: 2195686
#PIP4485: Low Boost, Reduced Power and/or DTC - keywords air cac charge control cooler driveability ecm engine gas hole lnf low maf mil P0101 P0299 P2178 pipe power reduced reducdpwrmde rub ses start stall - (Sep 26, 2008)
Subject: Low Boost, Reduced Power and/or DTC
Models: 2008-2009 Chevrolet Cobalt SS Only
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
If a technician encounters a low boost/power condition and/or dtc, the following may help.
Recommendation/Instructions:
When a technician encounters a low boost/power condition and/or related dtc on a 2008-09 Cobalt SS they should inspect the right side CAC-(Charge Air Cooler) pipe for contacting a radiator support bolt. Due to the location of the CAC on 2008-09 Chevrolet Cobalts a radiator support bracket bolt on the right front may make contact with the lower charge air cooler/hose from below. This contact may cause the CAC to leak boost or vacuum if a hole is present. Review the illustration to see the location of the suspect bolt. A thick washer may be added to the bolt to increase clearance.
Note: Bulletin 07-06-04-029 should be used to diagnose the charge air system when leaks are suspected. This bulletin may be aided by using the evap smoke cart to introduce smoke to the CAC system.
(1) Right lower radiator support bracket
(2) Right front lower Charge Air Duct concern
(3) This bolt will wear a hole in the Charge Air duct
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Š 2009 General Motors Corporation. All rights reserved.
Service Information 2008 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Document ID: 2206771
#PIP4520: Low Boost / Power And/Or DTC P0299 Or P0101 - keywords actuator boost CAC charge control cooler driveability DTC ECM engine gas lnf low maf MIL reduced reducedpwmde SES wastegate - (Nov 4, 2008)
Subject: Low Boost/Power and/or DTC P0299 or P0101
2008-2009 Chevrolet HHR SS Only
2007-2009 Pontiac Solstice GXP
2007-2009 Saturn Sky Redline
With Engine RPO LNF Only
Condition/Concern:
A technician may encounter a vehicle with a low boost/power condition and/or DTC P0299 and or P0101 setting. This may be the result of a cracked or broken fitting at the turbocharger assembly.
It has been determined that the nipple for the turbocharger wastegate actuator may be damaged causing this condition. If this concern is noted please inspect the area on the underside of the turbo compressor housing for the wastegate actuator solenoid valve. The nipple (see CALLOUT #1) may have been damaged causing a loss of boost pressure. It may be necessary to remove the charge air duct for a closer inspection. See eSI "Turbocharger Wastegate Actuator Replacement" for solenoid replacement procedure.
This solenoid is available separate from the turbocharger and should be replaced as a sub assembly. Do not replace the turbocharger assembly.
Service Information
Document ID: 2312877
#09-06-93-004: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator) - (Jul 21, 2009)
Subject: Intermittent MIL/Check Engine Light On, DTC P0299 or P0234 Set (Adjust Turbocharger Wastegate Actuator)
Models: 2008-2009 Chevrolet Cobalt, HHR
2008-2009 Pontiac Solstice GXP
2008-2009 Saturn SKY Redline
2008-2009 Opel GT
2008 Daewoo G2X
with Engine RPO LNF and LDK (Europe)
Please Refer to GMVIS
Condition
Some customers may comment that the SES light is on. Upon inspection, you may find DTC P0299 (Turbocharger Engine Underboost) or P0234 (Turbocharger Engine Overboost) set.
Cause
This condition may be caused by a mis-adjusted wastegate.
Correction
Note: The wastegate adjustment is sometimes a very fine process. When adjusting the wastegate, only small adjustments should be made. Loosen one nut at a time and only adjust the nut one turn at a time; then tighten the other nut against the shaft and test drive to verify. This may have to be performed several times to achieve the desired boost level. To ensure proper adjustment, the vehicle should be at full operating temperature when testing. The vehicle will be very hot and may need to cool between adjustments. Too large of an adjustment can cause repeat DTCs.
Adjust the turbocharger wastegate. Refer to Turbocharger Wastegate Actuator Adjustment in SI.
Troubleshooting Tips for DTC P0299 - Turbocharger Engine Underboost
To increase boost, adjust the nuts (in) towards the actuator; in essence making the shaft shorter.
Troubleshooting Tips for DTC P0234 - Turbocharger Engine Overboost
To reduce boost, adjust the nuts (out) towards the end of the shaft; in essence making the shaft longer.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J5799*
Use Published Labor Operation Time
*This is a new labor operation number. The next update of the Labor Time Guide will contain this number.
Old Jul 23, 2009 | 11:16 AM
Rissa's Avatar
Thank you!! <3
Old Jul 23, 2009 | 11:52 AM
aterminatorz's Avatar
Are you saying that when you are WOT that you are not holding boost? If you are only 50% throttle for example, you are not going to hold constant boost pressure as RPM increases.
Old Jul 23, 2009 | 12:00 PM
Rissa's Avatar
Yes WOT it won't hold it SOMETIMES. It's very strange.
Old Jul 23, 2009 | 12:18 PM
383_Stroker's Avatar
put your stock ecm in and run it to see if it still does it. Then you're know whether its tune related or not..
Old Jul 23, 2009 | 12:21 PM
Rissa's Avatar
Yup doing that again today.
Old Jul 23, 2009 | 12:25 PM
HB_SS/TC's Avatar
Hmmm and traction control is off?
Old Jul 23, 2009 | 12:26 PM
Rissa's Avatar
I don't mess with traction control lol.
Old Jul 23, 2009 | 12:31 PM
HB_SS/TC's Avatar
Try next time with traction control off and see what happens.
Old Jul 23, 2009 | 12:36 PM
  #36
Rissa's Avatar
But I've never messed with it before, and it used to be fine.
Old Jul 23, 2009 | 12:38 PM
  #37
HB_SS/TC's Avatar
That's true
Old Jul 23, 2009 | 12:39 PM
  #38
Rissa's Avatar
hmmmmmmmmmmmmm well I'm gonna drive around with it with the stock ecu you up until the meet on Saturday and see how it does then.
Old Jul 23, 2009 | 01:36 PM
  #39
rukkee's Avatar
I wasn't going to post this one cause it's kind of confusing ......But if since this is intermittent ...you might want to take a look.
Service Information
Document ID: 2298191
#PIP4669: Intermittent DTC P2261 Setting - keywords air boost cac charge chevrolet control cooler driveability ecm engine gas hole intermittent inf low maf map mil pipe power reduced reducedpwrmde ses turbo - (Jul 7, 2009)
Subject: Intermittent DTC P2261 Setting
Condition/Concern:
A technician may find DTC P2261: Turbocharger Bypass Valve Stuck Closed set with no problem found. It may be intermittent in nature or they may find the dtc will set after a hard acceleration, usually in third gear. DTC P2261 is a type B dtc and will not set on the first drive cycle the dtc sets, therefore multiple test drives should be performed to confirm repair.
SI diagnostics for this DTC states that the ECM compares the measured MAF reading to the modeled MAF and has detected a series of pulsations in the induction system that exceed a calibrated threshold. A snapshot of "Induction Data" will show the fault, however the tech may need to compare the snapshot data to another vehicle if they are unfamiliar with the readings. They should note a fluctuation and or a difference in the desired versus requested boost level. When diagnosing this dtc pay close attention to Circuit/System testing step #1. This step has you inspecting for any vacuum leaks, damage, restrictions, improper routing or connecting of the vacuum hoses on the charge air bypass valve solenoid, the charge air bypass valve, and the charge air bypass valve vacuum tank.
We have found leaking vauum tanks causing this dtc. When testing the vacuum tank, care must be used or the results may not be valid. The vacuum tank has an integral check valve not noted in SI. To check the Vacuum Tank operation, disconnect the hose that runs from the tank to the Bypass Valve Solenoid at the solenoid and apply vacuum to the tank. The tank should be able to maintain vacuum with no decay. Note: If you remove the vacuum hose from the intake manifold and plug it and the decay stops the check valve is leaking, if the decay continues the tank itself is leaking.
Note: Front wheel drive platforms using the 2.0 Liter RPO (LNF) incorporate a charge air bypass valve supplemental vacuum tank. The purpose of the tank is to provide an instant source of vacuum to the bypass valve via the bypass solenoid (when it is commanded open by the ECM). This results in less pressure buildup under closed throttle conditions, thereby reducing compressor noise, surge and spool time.
Old Jul 23, 2009 | 01:46 PM
  #40
Rissa's Avatar
yes I saw that one, and was considering it also, but my car has never shown a CEL so could that still be the problem?
Old Jul 23, 2009 | 01:50 PM
  #41
Permafried-'s Avatar
Someone please sticky the TSBs that have been posted here, poor guys have to keep posting the same stuff over and over again because they get buried and these ones (with images) could be incredibly helpful to others . On a side note, what in the hell were they thinking when they put that screw where they did
Old Jul 23, 2009 | 02:07 PM
  #42
rukkee's Avatar
It Should set a code , actually all of the tsb's and PI's i posted "should" , but there are always exceptions.
It would be nice .....I actually took the time to copy all those pics and change them to jpeg's (for the roll pin PI below ) so i could post them. About the screw ....lol.....nothing like putting a sharp pointy thing near a charge pipe lol...... that and the wastegate rod adjuster ....what a pain in the ass ... I was going to adjust the wastegate on my car but it wasn't worth the time to get to it.
Old Jul 23, 2009 | 02:13 PM
  #43
Rissa's Avatar
yeah no codes, but it's definitely acting up, I hope it's one of these problems!! lol
JonyyB
Dec 2, 2005 05:03 PM
