GM at it's finest!
Old Nov 21, 2012 | 08:35 AM
turbosmart4's Avatar
Wtf.............. Bastards
Old Nov 21, 2012 | 08:59 AM
emiller's Avatar
Why don't you blame the dealer? They broke your car.
Old Nov 21, 2012 | 12:00 PM
insylem's Avatar
Originally Posted by lees07g5
Had my trans 2nd gear replaced again, heard a hissing noise like a leaking garden hose, along with a roaring noise from the diff, tech didn't seal the end plate and it leaked most of the trans fluid out, took it back to them, had it resealed, few miles later noise got worse and then bam!, trans completely locked up. So, I put a new Exedy Stg 1 clutch n throw out bearing, AC Delco clutch master cylinder and found a nice used F23 trans off ebay. Their GM rep listens to the lying dealer about it all, case is getting back open soon as I call them with proof of the old locked up trans in my driveway.
Now I'm dealing with losing clutch pedal while driving at normal operating speeds, ( I've bled the crap out of it!) stop at a light or sign and wont go back into gear except for maybe 3rd on occasions and 5th if I'm lucky. I didnt know better while swaping trans to switch out the sensors and also, I didn't have the torx socket, at the time, to take the bolt loose for the bracket for the cables, so I was turning the plastic nuts beneath the bracket, could this be my issue, trans shifts perfectly with engine off! Thanks in advance guys, really need to figure this out asap.
I would think snycros but hard to say for sure.
Even with syncros bad it would still shift just fine if the car is stationary and the engine is off.
I don't really see how a clutch could really make it only shift in some gears and not others.
But the best of my understanding the Tranny has a seperate syncro for each gear.
Old Jun 9, 2013 | 09:36 PM
dtec's Avatar
help!! clutch/ gear issue
Hi I'm new to this forum and just bought a 2006 cobalt ss/sc....I bought it from some guy so it was a private sale meaning there's really no lemon law so I coulsnt return it.and he didn't want to give me the money back..long story short the day I bought it I was driving it home and within 20 minutes of driving it the clutch pressure seemed to drop a lot and only hooked up when it was very close to the ground..then it was very hard to get into gears..now when the cars cold it shifts smooth but the clutch hooks up near the ground and once is warm it doesn't go into gear please help me resolve this issue thanks!!
Old Jun 9, 2013 | 10:10 PM
redcobalt07's Avatar
Where is that stupid GM customer service rep?
Old Jun 10, 2013 | 02:12 AM
dtec's Avatar
Idk but do you guys think it's my clutch master cylinder?
Old Jun 10, 2013 | 02:19 AM
I think you should make your own thread instead of thread jacking
Old Jun 10, 2013 | 08:01 AM
emiller's Avatar
This is why you inspect it before you bought it. It wouldn't have mattered if it was a dealer either.
Redshift
Mar 31, 2009 10:16 AM
Chris(NJ)
Glimmer Glass Detailing
Jan 24, 2008 09:11 PM
