Got 3 different codes
Old Jun 10, 2010 | 02:11 PM
_UnLiMiTeD_'s Avatar
Has anybody had this codes before? Engine light has been coming on and off for the past few weeks, i was able to go down and get it scanned.
What would cause these codes? I have a K&N intake, LSJ downpipe and a muffler.
2007 cobalt ss 2.4
P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
P0520 Engine Oil Pressure Sensor/Switch Circuit Malfunction
Old Jun 10, 2010 | 07:26 PM
Malaclypsemus's Avatar
Possibly a short in the intake cam phaser circuitry. Or maybe a stuck solenoid or a stuck cam phaser. Best to take it in. Wost possible case is that your timing chain may have jumped time. That's not very likely considering the intake cam seems to be the only one affected.
Old Jun 10, 2010 | 07:28 PM
outtamymind's Avatar
dunno never had those before, i would take it in and get them to look at it. and if its been raining half as bad in bc as it has in alberta that don't help either
Old Jun 11, 2010 | 03:14 PM
ugh, i hope this **** aint expensive
Do you think these sensors would be covered under warranty?
Last edited by _UnLiMiTeD_; Jun 11, 2010 at 03:14 PM. Reason: Automerged Doublepost
Old Jun 11, 2010 | 03:22 PM
Permafried-'s Avatar
They should be. My guess is if you take a closer look you'll find water has made its way into the solenoid. Friend had something similar on his 2.4 cept he threw P0013 and P0014; he had to replace the solenoids but what out of warranty.
Old Jun 11, 2010 | 03:33 PM
Midwest Ecotecs's Avatar
yaa probaly what he said
Old Jun 11, 2010 | 03:55 PM
Where do i find the solenoid on the engine? I will try and take a look
Old Jun 11, 2010 | 07:10 PM
They're on top of the head between the #1 coil and the timing chain cover. Two cylinders, one with a black connector and one with a white connector. The one closest to the front of the car is for the intake.
Don't worry the solenoids are only $40 a piece. They'll be covered under powertrain warranty if you have it.
Old Jun 11, 2010 | 08:17 PM
I have the engine cover off, you think they will deny it because the engine cover is off an exposing those?
what about the oil pressure sensor? where is that located? Throwing a code for that as well
Last edited by _UnLiMiTeD_; Jun 11, 2010 at 08:17 PM. Reason: Automerged Doublepost
Old Jun 12, 2010 | 03:57 AM
No way in hell.
From what I've heard its screwed into or just below the oil filter housing.
Old Jun 12, 2010 | 04:28 PM
alright, thank you, going to make an appointment this week with the dealership
Old Jun 25, 2010 | 12:40 AM
sparky305's Avatar
P0011 and K&N
How long have you had your K&N filter in? I recently put one in my ION and immediately began experiencing hard shifts, an illuminated engine light, and low and behold a P0011 code. After I spent hours on Saturn, HHR, and Cobalt sites seeing similar issues, I Googled "K&N code P0011". There seems to be more results with this combination than all of my other inquiries combined.
Old Jun 28, 2010 | 10:42 PM
K&N has been on for 6 months. It end up being the engine oil pressure switch causing all the problems, which was one of the codes. But when that failed, it caused the other ones to act up since they work in relation with it.
Old Jun 29, 2010 | 08:30 PM
Malaclypse's Avatar
Glad it was a simple fix.
Old Jun 29, 2010 | 09:38 PM
well i take it back, started laggin betwen 3-4k again, piece of ****** ****
Old Jun 29, 2010 | 11:14 PM
Malaclypse's Avatar
It probably needs that intake cam phaser solenoid. I ran into that on my 2.4 not long after I got it. There was a bog in certain RPM ranges.
The dealer likely went after the oil pressure sensor because it -can- affect everything.
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
