Got the Infamous P0107 code
Old Oct 11, 2009 | 10:10 PM
Black08SSTC's Avatar
So i was at the track. First pass went well, got a 13.4 at 26mph lol (stupid dragway). They were busy as **** and i waited about 2hrs for my next pass. On start up i saw the check engine light go on, went to stage no burnout and proceeded down the track cautiously. had the code read by 06BlackG85ss, he cleared it and then it came back 10 seconds later. Just wondering whats involved to get it to go away lol. Im tuned at 25psi spike but have been for about 3000miles and have pushed it before. Just wondering why it blew now?? Do i just need to replace the sensor?? any ideas would be cool
bumpage
also whats the part number for this sensor?? where can i get another one??
Last edited by Black08SSTC; Oct 11, 2009 at 10:10 PM. Reason: Automerged Doublepost
Old Oct 11, 2009 | 11:25 PM
Ferretts's Avatar
Fail!!!!!!!!!!!!!
sorry i dunno.. i would check my car but you kinda know the sit. with that... you might wanna check your tune, 26 mph seems a little low for a tuned tc, especially one with the factory freak numbers your making
Old Oct 12, 2009 | 08:23 AM
Originally Posted by Ferretts
Fail!!!!!!!!!!!!!
thanks for your support and knowledge, you fail.
I bought the map sensor GM-12592016 for $60 bucks from GM Parts Direct. Dealership wanted $100
Old Oct 13, 2009 | 07:35 PM
Turbo06Sedan's Avatar
check your rear o2 sensor too and see if you blew any fuses in the process.
Old Oct 13, 2009 | 11:35 PM
StageII07's Avatar
I got this code tonight it goes on an off, if i sit an idle for a bit it comes on..i think its either my front or rear 02 sensors..always give me it..i also saw a p0069 code today odd..
wait correction i saw u said p0107 i get the p0171 code..lmao
Old Oct 14, 2009 | 10:33 AM
P0107 lol its not the 02 its the map sensor
Old Feb 12, 2010 | 04:37 PM
BlackyK's Avatar
I'd like to bump this thread with my P0107 CEL. For the last 3 years, I've had the F5 intake with zero problems and I just changed my air filter (****** was rusted over and crushed in my hand when I took it off) And I forget to D/C the battery while I was doing it and went to a dinner meet that night. Boosted a bit on some on-ramps and it came on, and been on ever since. About 3 weeks now. I thought it was a small slice in the rubber connection tubing but I just examined the entire intake thoroughly and the slice didn't cut all the way through. Still Gorilla glued it together to be safe. I got the code checked by good old Mikey and it was Bank 2. Is that the sensor right on the snout of the SC? I just cleaned the whole intake inside and out and checked all the connections. If I still get the CEL, would that mean the sensor is shot? All the wires and hoses are flexible and don't seem clogged up. And which sensor do I order from GMPD? Thanks for the info & help!
Old Feb 14, 2010 | 06:49 PM
BlackyK's Avatar
Bumpin' for love of my CEL still on.
Old Feb 15, 2010 | 03:33 PM
09redsscobalt's Avatar
im guessing u have the GMS1 kit in it and ur wanting the map sensor for that kit.
I have the kit too and got the code a couple of days ago. I installed it myself at work with the crimp connections they give you. A master tech here said those connections could be causeing the problem. So we saudered the wires and havent had the code come back since. Maybe you should try that before buy a new sensor. the car seems to be running fine now
It should be warrenty cause the kit is GM. If it comes back on for me, im gonna have them warrenty me one.
Old Jun 5, 2013 | 01:16 PM
rchiwawa's Avatar
Thanks for the part number, I just bought mine off of Amazon for $40 fwiw
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
OrangeCoba
Sep 25, 2015 06:06 PM
