Grinding into gears (repeating issue)
Old Apr 18, 2008 | 04:15 PM
08slobalt's Avatar
Exclamation Grinding into gears (repeating issue)
I was just wondering if any of you were having issues with your cobalt grinding into third and fourth gear. I had it fixed and now it's doing it again. It mainly happens when I down shift but it does do it when I up shift also. It will be going in soon for the second time to be fixed and one more time after that I think I will be pushing for the lemon law.
Old Apr 18, 2008 | 04:18 PM
Firebirdhorn's Avatar
me too......mine did that as i pulled off the lot....I have an 08 as well......but if you shift very slowly into 3rd and 4th it wont grind....
Old Apr 18, 2008 | 04:22 PM
rallyracer's Avatar
Get your RPM's up higher and see if that helps.
Old Apr 18, 2008 | 04:24 PM
D4u2s0t's Avatar
never grinded a gear unless it was just a bad shift.
is it a syncrho problem or are you letting the clutch out too early
Old Apr 18, 2008 | 04:38 PM
I think its a synchro problem with the new 08's. me and this guy arent the only 08's that this has been happening too, especially in only 3rd and 4th.....trust me, i'm not shifting stupid, its just a problem with these cars it seems like. Like i said earlier, it happened to me driving it off the lot with 45 miles on the clock. My black 07 did not have this problem at all
Old Apr 18, 2008 | 04:50 PM
CullinanCut's Avatar
My 07 does this as well, has since I bought it but usually only in 3rd. I thought at first it just needed to be broken in so I let it go until now. I don't drive it hard too often and even then I'm easy on the transmission. I took it to the dealer and after 4 hours their response was that it was due to "aftermarket floor mats"! They said the floor mat wasn't allowing the clutch to engage all the way. I called BS and asked why it only happened in 3rd but they didn't have a good answer. Just to make sure that I wasn't wrong I took the mat out and drove it and of course it still did it. I guess I will have to take it back with no mats and see what they say
Old Apr 18, 2008 | 04:55 PM
invisible's Avatar
Thats a new one on me. Tell them to go f&^% themselves and fix it.
Old Apr 18, 2008 | 05:01 PM
D4u2s0t's Avatar
that's the best excuse for denying warranty work i've ever heard!! should of asked them where the engage point is, and watched them look at each other in confusion
Old Apr 18, 2008 | 05:13 PM
thats bullshit....how retarded
Old Apr 18, 2008 | 06:10 PM
Haha I couldn't believe it myself. I had to laugh though at the way he said "aftermarket" floormats! Lol Evidently that's the key word for denying warranty work! He pointed me towards the parts department and told me to pick up some cobalt specific floormats and that would fix the problem
Old Apr 18, 2008 | 10:11 PM
08slobalt's Avatar
yeah they told me the same **** with the floormats also I told them to where to stick it. Then I took the matts out and it still did it they then fixed it. Now it's doin it again. It does it all the time low RPM and high as long as it's a downshift and sometimes upshift. I bought the car with one mile on it and it's done it ever since. I'm easy on the car most of the time I do race it in a series but we only had one event so far. So now it's goin in again and we will see after that.
Old Apr 30, 2008 | 09:21 AM
08slobalt's Avatar
So I was getting ready to leave work the other day and when I went to put my car in reverse it was so hard to do I had to use two hands. I got off the clutch before doin that to see if it was just being crazy but it wasn't. Then pulled it out of gear and tried it again and then it grinded and thuded into gear. WTF is the deal with these transmissions. There is a guy from GM and he is located in Detroit and he will personally go out and look at the problem if you are within a 100 mile radious of Detroit. This guy only deals with the cobalt trans issue that's it so if you have a trans issue and want to get it fixed and live within 100 miles of Detroit then your in luck.
Old Apr 30, 2008 | 02:35 PM
08redls's Avatar
mine grinds when i shift fast but if i drive normal then they go in fine.
Old Apr 30, 2008 | 02:38 PM
06BrandonSS's Avatar
Mine has only ground going into reverse, usually every couple days it will happen, but mines an 06 so its a little different with your 08's.
Old Apr 30, 2008 | 02:40 PM
07LaserBlueSS's Avatar
mine is kind of in between it only slightly grinds just enough to tell, but i had the trans rebuilt under warranty a few months ago for a input shaft going bad. WTF
Old Apr 30, 2008 | 03:57 PM
08slobalt's Avatar
Yeah the dealer told me to keep a close watch on what goes on with the trans so I think they will fix that problem also I don't know what the lemon law consists of but I think I am close to having that issue also
Old Apr 30, 2008 | 06:16 PM
pare_john's Avatar
I am having the same issue both when upshifting and downshifting. But it is only when i shift very fast, otherwise it is ok
Old May 1, 2008 | 01:58 AM
chevy cobalt 08's Avatar
08 here have the same issue too but it seems to not do it if you shift into them slower than 1,2, and 5. i usually only have it going into fourth so i kinda do the double clutch method without the double clutching...hitting n first then 4th all with the clutch still down i think its a synchro issue
Last edited by chevy cobalt 08; May 1, 2008 at 02:01 AM. Reason: Automerged Doublepost
Old May 1, 2008 | 09:53 AM
john80's Avatar
my 06 had the same problem i took it to the dealer and i had to get a new tran hope it don't do it again
Old May 1, 2008 | 10:22 AM
PlaysWitCars's Avatar
Former Cobalt Owner
my 3rd gear is grinding unless i delay the shift........so new synchros for me!
biniecki
Oct 25, 2015 02:23 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
