headlight issue
Old Sep 26, 2010 | 03:16 PM
Dragonsfire12345's Avatar
headlight issue
at first I thought it was just either my hid bulb or harness giving out but its not that. My driver side headlight does not turn on. The signal light and side marker do work, but not the headlight. When I first started noticing my headlight giving out my bulb went from blue to a bright white. Then last week it finally gave out, I've tried a stock 9007 bulb to check and it still doesn't work. I'm at a lost right now and can't figure it out.
Old Sep 26, 2010 | 03:30 PM
Another thing I just noticed, the hid that is burned out. The +wire has burn marks on it
Old Sep 26, 2010 | 03:46 PM
And I tried the headlight harness from the other one and still nothing
Old Sep 26, 2010 | 03:47 PM
TommyP's Avatar
AWD > FWD
I'm gonna guess you burned out the wiring or there was a large short. Are you running a relay harness with your hids?
Old Sep 26, 2010 | 04:03 PM
It's just the ballast and hid
Old Sep 26, 2010 | 05:51 PM
figured it out, there was water inside the ballast connector. Guess thats what blew the fuse..... I didn't know each headlight had a fuse for itself.
Old Sep 26, 2010 | 05:53 PM
TommyP's Avatar
AWD > FWD
Yup, fuse for each, guess it was a short. Good job on the fix. Always good to see it's just a fuse and something simple.
Old Sep 26, 2010 | 08:08 PM
yup same here
Old Sep 27, 2010 | 02:58 AM
insylem's Avatar
YOur wire is probably toasted and the smoke escaped...
Cant put the smoke back in, youll probably need to rewire it. Check your fuses.
Sounds like something either shorted, or your lights were pulling more current through the wires then they could handle.
Trav3480
Oct 1, 2015 08:17 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
