headlight wont stay on
Hey i saw a post on this issue before i had it but now i cant find it so im gonna ask for help. My driver side headlight wont go on. I got new headlights and it still wont so I know its not the headlight or bulb its gotta be something else. It turns on when im walking up to my car and i unlock it, just when im in my car driving it wont go on. The other side works perfect. I cant figure out whats causing it
No HID's. And yeah now that i think of it those are the high beams. Both high beams work. The driver side low beam doesnt. All fuses are fine i just checked. And the light doesnt even blink, its not on at all.
Bulb blew? Wire short? Check all your connections carefully, you'll find the problem.
If you have new bulbs, it must be a fuse.
Put the side that doesn't work in the side that does.
If it works its either a bad fuse or somethings wrong with your wiring.
If it doesn't work, then its the bulb.
well i had my old headlights and the light was out. so i got new bulbs and it still was. so i got new projectors and its still out. so i changed the fuses and the bulbs again and its still out, so idk lol.
There has to be a seperate wire for high and low. Those bulbs have three pins on them for three seperate wires. If its not a fuse, and a brand new bulb like others have said already it has to be a wiring issue. How does the pigtail look? Not heavily corroded or anything?
