hearing a squeak
hearing a squeak
I keep hearing a squeak but i can't pinpoint where it is coming from. I think it is coming from somewhere inside the car but i can't tell. It could be from the rear suspension too. Maybe also due to the fact that my driverside rear quarter panel jiggles. It is like the clips are not holding it in place. You guys know so much figured your endless knowledge can help me out.
Theres a known problem with the back seat latches,there is a tsb on it.
Also if you got head rests check the passanger one mine had a annoying chirp when I hit a bump.
Squawk/Squeak Type Noise From Rear Suspension While Driving Over Bumps at Low Speeds (Replace Rear Suspension Insulators) #06-03-09-005A - (06/22/2006)
#07-08-50-001A Squeak or Chirp Noise from Rear Split Folding Seat Back or Seat Cushion While Driving (Install Squeak Reduction Tape) - (Aug 28, 2007)
Here they are
#05-03-10-006B Wheel Squeak (Install Wheel Cover Insulators) - (Jun 27, 2006)
Here they are
Here they are
Here they are
lol the 3rd tsb is for hubcaps, he has an ss so process of elimination takes that out
It's def. annoying, for me it comes from the left rear of the car, sounds like it's on the inside of the car. I'd believe it if I was told it was the back seat latches, I'll have to fold my seats down today and ride around to see if it goes away.
This fan thing you speak of, does it make a clicking noise? I hear a clicking from the passenger side dash vent, on speed 1, and it clicks faster on speed 2, then goes away (or is covered by the noise) on the higher speeds.
Might work, but you'd probably be in there replacing the tape every so often
so suspension could be a culprit too huh....control arm bushings in the front and is there anything in the rear suspension that could be making it squeak?
what about the lose left rear bumper right behing the drivers side rear tire. How many people has that problem?
