Heater always on
Left is for A/C and will turn on the compressor and radiator fans.
Center is the rear defrost.
Right is the one I'm referring to and will turn on recirculate. This only works if the left knob is set to vent, e.g. not windshield or foot.
My 06 didn't do it, neither does my 09. Just did it, compressor does not turn on unless you put it into windshield defrost or press the A/C button. Think you've got something up with yours if that's the case.
It's basically air getting pushed in from u driving. Wish they would have a way of shutting the vents on the outside completely. I had a truck where that's the only way I got heat is from it being pushed into the cab while driving, fan motor was busted, so I had to freeze till ten minutes into my drive
My 07 and my 09 do it, its not full load compressor but its on
