Help/advice
Old Sep 15, 2010 | 12:04 PM
Cobalt_Daddy's Avatar
Help/advice
Driving home today.. Got low coolant for a second then went away... 10 minutes later temp climbs to 110C so i pull over and shut the car down.. Pop the hood... No visible leaks or splashmarks.. Resevoir is empty.. Now waitig for a tow truck to take it to the dealership.. Any ideas? May check the dip stick for coolant..
Old Sep 15, 2010 | 12:06 PM
Chevycobaltss3's Avatar
if you got low coolant you are either eating it into the cars engine or you are sending it out, so either way it is warranty work. I say its a head gasket issue if you have no leaks... good luck bro
Old Sep 15, 2010 | 12:08 PM
Just checked under valve cover oil fill cap .. definately coolant on it.. Watery beaded substance on cap itself and i doubt condensation builds up in there...
Old Sep 15, 2010 | 12:55 PM
blown head gasket wuts the boost your running.
Old Sep 15, 2010 | 12:59 PM
GMS1 tune so 20PSI.. Warranty but sucks wasting your afternoon off waiting for some ******* towtruck diver taking his time when the garage is literaly 5 minutes away and ive been here over an hour since i called...
Old Sep 15, 2010 | 01:08 PM
Yeah I understand bro... My old Ss sc I had it towed prob like 20 times lol good luck
Old Sep 15, 2010 | 02:17 PM
Dealer is checking it.. Wondering what my rental will be
Old Sep 15, 2010 | 02:32 PM
BlueStang's Avatar
^ Most likely a Cobalt
Old Sep 15, 2010 | 03:38 PM
ford fuckus coupe... not a bad little car... lots of features... but it handles like a sack of potatoes
Old Sep 15, 2010 | 03:46 PM
Lmao hopefully u cracked a sleeve and they give u a new engine jk
Old Sep 15, 2010 | 04:24 PM
i wish... but because i didn't get any dummy lights or warnings... just my intuition when the temp climbed to 110C i doubt it. car is at dealership now we'll see what they say tomorrow... oil didn't look right to me.. to watery .. as i said moisture on the fill cap... which im not sure is normal. that and what car eats coolant bone dry in two days without having any smoke or visible leaks. :/ checked it two days ago when i got low coolant in driveway on startup... checked overflow and it was down maybe an 1/8 of an inch.. barely below cold line so chaulked it up to car sitting on a bit of an angle and playing with the sensor... guess it wasn't... but car wasn't driving good all day... boosted to 20psi no problem but didn't seem as peppy at times..
Old Sep 15, 2010 | 04:32 PM
Prob because ure water jacket was blown to the oil jacket so head gasket issue
Old Sep 15, 2010 | 04:41 PM
could be... we'll see i guess :/ and i better not get any accusations that i beat on my car and caused it... because that's B.S. i have fun with it but don't beat on it 24/7. do regular maintenance at dealership and am very careful about any problems. I even pulled over before i got a warning and a too late light saying my engine was cooked... so we'll see... tow truck driver said he had a coworker with an SS and engine blew... dealer checked computer and said he drove it too hard... spent alot of time at redline... not sure how it's logged in history but i would think only problems showing will initiate a logging of RPM, boost, etc. when the light or problem occurs... but again i'm not sure... was doing roughly 110km/h when i noticed temp climbing so i pulled over before it was too late. Not beating on it or driving it hard at all...
Old Sep 15, 2010 | 04:50 PM
They can see history but I'm not totally for sure wut all they can see
Old Sep 15, 2010 | 04:54 PM
wonder how far back it logs too... even still as i said i don't drive it at redline all day... i may give it getting into traffic once in a while.. but i don't race it all day..besides that the motor was built to take boost so it shouldn't grenade at 36,000km. the only thing i am guilty of is getting on and off the gas in a city drive to get the BPV sound i love but that doesn't require anywhere near redline so i dunno....
Old Sep 15, 2010 | 05:25 PM
U will be fine bro don't worry an if they say it's not covered ask to talk to a Corp rep. It's like the same thing with a vette owner. They can add mods
and blow a motor up but they get away with it trust me I've seen it with all my Buddys
Old Sep 15, 2010 | 05:29 PM
thanks!!
jay4901
Jul 6, 2015 12:24 PM
nixiee_ss
Jul 13, 2014 09:31 AM
Tmarter
Nitrous Oxide
Jul 11, 2013 06:18 PM
Jephron
May 13, 2013 04:37 PM
wRcKLes
Apr 21, 2013 11:03 AM
