Help coolant hose disconnected
Car Idles Like SH*T , whats going on
yesterday i was driving and i went to get food , got on it in second a little , shifted at about 6k into third and shut it down at about 80 well then i went home chilled for like 3 hours go back out to the car and when it starts it idles like the throttle body sensor is unplugged , so i thought it was the coolant thing but i was wrong , so i changed my spark plugs , still idles like the throttle body sensor is unplugged ,i dont know what is going on , the car is in limp mode and it will not come out !!!!!! the reason i know the way it sounds when it is unplugged is because that was the one thing i forgot to plug in when we put the blower on when swapping pulleys ,
Last edited by Red2.4SS/SC; Apr 29, 2007 at 02:08 AM. Reason: Automerged Doublepost
yesterday i was driving and i went to get food , got on it in second a little , shifted at about 6k into third and shut it down at about 80 well then i went home chilled for like 3 hours go back out to the car and when it starts it idles like the throttle body sensor is unplugged , so i look and make sure its plugged in and it is , then i look at the coolant thing right in front of the blower where its held together to a braket with 2 screws , well the skinniest cord on the coolant thing is totally disconnected from my car and i have no idea where it goes , anyone know???? i have pics but no cord to load them on the computer
here is what im talking about , the hose in red is disconnected
bump anyone
bump anyone
Is it the rubber hose thats disconnected, or did the fill neck come disconnected from the rest of the aftercooler cooling system?
If its the rubber hose, one end is connected to the fill neck, the other is just a vent to the atmosphere. Its an overflow line.
yeah the other end that goes into the engine bay is disconnected
when i start my car it says engine power reduced , ive checked my TB sensor , i havent checked the plugs OR disconnected the battery
Last edited by Red2.4SS/SC; Apr 28, 2007 at 01:04 PM. Reason: Automerged Doublepost
thats normal its not connceted to anything other then the resiviour u have another issue that doesnt involve your cooling system..
Check where your intake pipes are connected for leaks, check the sensor on top of the supercharger, check the map, baro, and maf sensors to make sure nothing come loose.
yeah im also running a 2.6 and im getting worried , like i might have blown my motor ,but its doiing the same thing it was when the throttle body sensor was unplugged hopefully i can fix it
well i just put my stock plugs back in and its still messed up , i wonder what the deal is , im not throwing any codes or anything , the car just idles like the throttle body sensor is unplugged
that could be it , or it could be some loose wire somewhere BUT not around where it plugs into the throttle body ?? i dunno what it is , im gonna try and re load the tune and see if it still runs like it
Sl0wbaltSS
Nov 21, 2018 11:11 PM
OrangeCoba
Sep 25, 2015 06:06 PM
