Help me please! Blown Clutch?
Old Dec 5, 2005 | 05:40 PM
glockglade's Avatar
Hey I have the ss s/c and the other night while racing when I shifted from 1st to 2nd the engine rpm held around 6k for 3 or 4 seconds then dropped down to around 4k and went through the rpm band like normal, then last night while racing again it did the same thing except it didn't drop back down to 4k it went to redline and bounced off of it so I switched to third to try and get out of it but it did the same thing in 3rd so i let off the gas and it then went through the rpm band. I also after popping the hood smelled something unusaul from the engine most likely clutch is this what the problem is or could it be something else. I took it to dealer today they said that they couldn't even check it out b/c the guy driving it to test drive it wouldn't take it that high through the power band and it only does that while shifting hard normal driving is fine. I am so confused and don't want to spend a grand on a new clutch if it isn't the problem. Thank you for responding.
Old Dec 5, 2005 | 05:45 PM
Chevypowered's Avatar
Take it back and take the tech for a drive but if it is blown they prob won't cover it.
Old Dec 5, 2005 | 06:29 PM
MOD MONEY's Avatar
mine's gone 2 waiting on stage2 and flywheel
Old Dec 5, 2005 | 10:21 PM
glockglade's Avatar
Thing though is I haven't really pushed it alot. P.S. There are three clutches out already, exedy, centerforce, and spec. I was told to get the exedy and that it is a great clutch.
Old Dec 9, 2005 | 11:43 PM
redbaltsssc's Avatar
if there is air in a hydraulic clutch system it can keep the clutch from fully ingaging allowing it to slip.
Old Dec 10, 2005 | 01:59 PM
boostedss26's Avatar
Mine is doing the exact same thing. I brought it to the dealer and they are replaceing the clutch, fly wheel,slave cylinder, pressure plate and bearings. I took the tech for a drive cuz they also wouldnt beat on it to make it slip
Old Dec 11, 2005 | 12:26 AM
fiShYs-'s Avatar
that happened to me once
when i was racing i was on 3gear, when i shifted to 4th... the rpm kept going up to 6k after the clutch has been released... after 3-4 sec it drops back down to 4k.... scared the **** outta me
Old Dec 11, 2005 | 10:03 PM
chevytech329's Avatar
<if there is air in a hydraulic clutch system it can keep the clutch from fully ingaging allowing it to slip.> -
thats wrong
The pressure plate spring holds the pressure on the clutch disc. the clutch pedal releases
the pressure through a master cylinder and slave cylinder. If there was air in the system
it wouldnt release completely and would grind into gear.
fyi
Jeff
2005 SS/SC
Old Dec 11, 2005 | 10:39 PM
05_Blue_B10WN_SS's Avatar
I have the same problem. Will be taking it to the dealer after winter.
Old Dec 11, 2005 | 11:04 PM
BowTieCobaltSSSC's Avatar
Mine has done the same thing only has 1560 miles on it .
To GM's Clutch
Old Dec 17, 2005 | 02:25 PM
You cannot have air in the clutch line because the slave cylinder runs off of the brake master cylinder so if you had air in the line you would also have it in the breaks and your peatle would be mushy!
Old Dec 20, 2005 | 06:04 AM
jfegel's Avatar
I just recently got a 06 ss/sc yellow and i have had the clutch slip while shifting into 2nd above 4500rpm as well. only have 1400miles
Old Dec 20, 2005 | 08:57 AM
Spastic Chicken's Avatar
Slippage here between 3k and 4k.
Old Dec 20, 2005 | 10:36 AM
R33P3R007's Avatar
360 L337 User
yup... 6-7k on mine same deal
Old Dec 20, 2005 | 10:42 AM
BLKSS's Avatar
hmmmm did it smell like gun powder or rotten eggs?>
Old Dec 20, 2005 | 10:57 AM
VaMP's Avatar
Wow slippage right in the peak of the powerband. Sure it wasn't the tires? Was their an oder?
If you're capped at 6500 then how the hell do you notice slipping with only 500RPM's difference?
Old Dec 20, 2005 | 02:33 PM
mrbelvedere's Avatar
you never tell the dealer you were racing your car if you want them to cover it under warranty
mrb
Old Dec 20, 2005 | 03:03 PM
NEss/sc's Avatar
had the same thing happen to mine. was in 2nd went to 3 anthen tryed to accelerate and i had major slippage. let of and it hasnt done it since. i talked to my uncle and he said that gases can build up if the cluch gets too hot
Old Dec 20, 2005 | 03:24 PM
For most of us that experience this it isnt just a one time thing. I get slippage regularly. The clutches in our cars are crap.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
ThoR294
Sep 28, 2015 05:31 PM
