help with p0341
help with p0341
i rebuilt the motor in my car and ichecked the timing twice and its right
intake 2 oclock
exhaust 10 oclock
cylinder one tdc
but its setting a p0341 for the camshaft position sensor and im kinda stuck...... can soneone help me out
bumb
intake 2 oclock
exhaust 10 oclock
cylinder one tdc
bumb
okay most of that requires a scan tool or a multimeter
i could see the sensor being bad but i dontr know how i left it in my room.
okay well i checked the connector and found that it has a power and ground and when the signal was grounded to motor made some funky sounds lol. but i forgot to tell you that when i had the sensor disconnected it set a p0341 and p0340. when i connected it the p0340 went away, i dont think a crankshaft variation relearn will work because the motor has to be running. overall do you think the sensor is just bad period?
