help with p0341
Old Jul 29, 2008 | 10:13 PM
madmark's Avatar
help with p0341
i rebuilt the motor in my car and ichecked the timing twice and its right
intake 2 oclock
exhaust 10 oclock
cylinder one tdc
but its setting a p0341 for the camshaft position sensor and im kinda stuck...... can soneone help me out
bumb
Old Jul 29, 2008 | 10:14 PM
Raven SS's Avatar
thats cuz its not ur timing
Old Jul 29, 2008 | 10:20 PM
Coblasts's Avatar
Check your email !
sent you some info.
I think it might be the gap for the sensor is not right ,but also check your connections and wires incase you damaged something.
Old Jul 29, 2008 | 10:42 PM
madmark's Avatar
gap for my sensor? what are you talking about its a 2.2..... the sensor only goes in one way and i dont think you can space it
Old Jul 29, 2008 | 10:45 PM
Raven SS's Avatar
hes referring to where u plug it in in the back...ur cam positioning sensor is bad
Old Jul 29, 2008 | 10:47 PM
Coblasts's Avatar
Check out the info I sent you and let me know.
Old Jul 29, 2008 | 11:09 PM
madmark's Avatar
okay most of that requires a scan tool or a multimeter
i could see the sensor being bad but i dontr know how i left it in my room.
okay well i checked the connector and found that it has a power and ground and when the signal was grounded to motor made some funky sounds lol. but i forgot to tell you that when i had the sensor disconnected it set a p0341 and p0340. when i connected it the p0340 went away, i dont think a crankshaft variation relearn will work because the motor has to be running. overall do you think the sensor is just bad period?
Old Jul 30, 2008 | 06:10 PM
madmark's Avatar
replaced the sensor..... same code still pops up any ideas
Old Aug 10, 2008 | 09:48 PM
cobaltssredtint's Avatar
i have the CODE p0365........but mine says that its not hook up...i don't know where to find that sensor
Old Aug 12, 2008 | 09:26 PM
sparhawk's Avatar
this may sound dumb, but did your cams have a relector ring? from the technical info i have the p0341 sets if the cmp does not generate a signal.
JJohnson479
Jan 28, 2014 08:04 PM
Just2Bad
Sep 14, 2010 11:54 AM
rukkee
Jul 9, 2010 05:55 PM
rukkee
Sep 21, 2009 06:47 PM
