HELP!!!!!!!! Reset timing and car is cranking but not turning over.
Old Feb 26, 2016 | 10:08 PM
Lucid Dreams94's Avatar
I reset the timing on the car according to spec and the car started and ran for 5 minutes and died. Went to restart is again and it just cranks. Sputters out the exhaust but won't start. What could this be? I have absolutely no idea what it could be. 😔
Old Feb 27, 2016 | 02:00 AM
Psykostevo's Avatar
I know the LSJ is really picky to mechanical timing. If it's not perfect the ignition won't fire. Been a long time since I've tackled that issue, but double check your work and make sure it's really up to spec.
Old Feb 27, 2016 | 07:45 AM
Omiotek's Avatar
You probably jumped timing. Chances are you didnt have it times properly or did not set the tensioner properly if that was the only thing you did. Did you do anything else
Old Feb 27, 2016 | 05:09 PM
cluelessk's Avatar
Reason for "resetting" timing?
If you're going that far aren't you best off replacing wear items?
Old Feb 27, 2016 | 05:35 PM
06_ion2's Avatar
Maf or O2 unplugged?
Old Feb 27, 2016 | 09:25 PM
ItalianJoe1's Avatar
More info would help here.
I'm also local and could help you out, i've done everything you can possibly do to a cobalt.
Old Feb 28, 2016 | 06:00 AM
I was putting the factory cams back in it. Thats all I did.
Old Feb 28, 2016 | 09:45 AM
Omiotek's Avatar
you need to supply more info... i asked questions and you did not answer them all.... if all you did was cams you probably jumped timing or something came unplugged.
have you checked for codes?
ricklovin93
Mar 20, 2016 10:04 AM
CobaltHunter
Feb 27, 2016 02:01 AM
rocco11189
Feb 23, 2016 07:23 AM
Jay P.
Feb 23, 2016 12:45 AM
jcalvin1126
Feb 17, 2016 02:02 PM
