Help: weird sound, sway bar link lose??
Old 03-31-2009, 02:35 PM
soga831's Avatar
Thumbs up Help: weird sound, sway bar link lose??
Pros,
My bolt makes a noise when I go through an uneven surface...We looked at it and one of the sway bar link at the front driver side is a little lose, it makes a sound when you knocking on it...Here are my questions:
1. Is this the cause of the noise when goes through uneven surface? Did anyone have problem with their sway bar links?
2. I want to replace the parts, any recommendations? I know there are a set with SE5 sport suspension, and a set without, what's the difference?
Appreciate any commands...
Old 03-31-2009, 06:31 PM
DaBuzzard's Avatar
Lots of people with the same problem, sounds like the links in our cars are not the greatest. And yes, if it feels loose / clunky when you grab it with your hand, it is likely the source of your noise. Uneven surfaces will load up the links more than even bumps (like a speed bump).
Not sure what the difference in the links is from fe1 / fe3 / fe5. Not sure if you can swap them.
Mavin is the man on this stuff, you can usually find him in the suspension forum....and there is a handy sticky there that may answer your questions.
Old 03-31-2009, 07:33 PM
css9450's Avatar
FE5 links are shorter than the others by about a couple inches.
My links were starting to wear out and rattle terribly. I bought some replacements (OEM style, by Moog, not the performance ones by Bwoody and others) and it was like having a new car again.
Old 04-01-2009, 12:27 PM
soga831's Avatar
they are not expensive, the OEM ones, I guess I will just go with them since I don't have to worry about whether they are fit or not...
Thanks for all the replies...
Old 04-12-2009, 02:20 PM
ryananstey1986's Avatar
can somebody post a pic of where the endlinks are? thanks
Old 04-12-2009, 03:57 PM
jerrodmann's Avatar
whoa whoa whoa, wait a minute, i thought we didn't have aftermarket links???
Old 04-12-2009, 06:23 PM
css9450's Avatar
Oh, but we do!
Old 04-12-2009, 09:28 PM
jerrodmann's Avatar
website?
Old 04-14-2009, 05:59 AM
can somebody post a pic of where the endlinks are please?
Old 04-14-2009, 01:15 PM
DaBuzzard's Avatar
On the end of the swaybar, they connect the bar to the strut. One on each side.
Old 04-14-2009, 01:18 PM
whats the advantage of the performance ones?
biniecki
10-25-2015 02:23 PM
jimbofug007
10-02-2015 12:06 PM
OrangeCoba
10-01-2015 10:00 PM
SSLOW06
10-01-2015 07:21 PM
DANRICKARD
10-01-2015 12:08 AM
Quick Reply: Help: weird sound, sway bar link lose??
