HID install issue
Old Jan 19, 2010 | 05:03 PM
BumbleBee's Avatar
HID install issue
Ok I got this kit
http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
I have the 1st Gen halo projectors.
My only problem is where the 2 male pins go that are close to the bulb, it says they plug into a socket, but that doesnt help me. imma noob at wiring .
please help me out its gotta be simple.
Old Jan 19, 2010 | 05:07 PM
PsychoCam's Avatar
When you take out the h1 bulb in ur gen 1 projectors there is a positive blue wire on the top of the bulb and a negative black wire attached to the bulb housing.
You connect the red wire from the hid bulb to the blue wire mentioned above
you connect the black wire from the hid bulb to the black wire mentioned above.
understand?
Old Jan 19, 2010 | 05:28 PM
BumbleBee's Avatar
that makes complete sense thank you soo much, but now lol the hid bulb looks like it will slid right in but it hits something and i have no idea what, like the hole is too narrow im not sure. i dont wanna force it in and break the bulb
Old Jan 19, 2010 | 05:31 PM
07cobaltguy's Avatar
i had to use a dremel with a cutting bit to remove a little bit to makethem work
Old Jan 19, 2010 | 05:44 PM
BumbleBee's Avatar
ok, i did that and now the bulb goes in but it doesnt spin or twist to line up the nubs or do they not have to?
running out of daylight lol
Old Jan 19, 2010 | 05:45 PM
YelloEye's Avatar
The nubs should line up, I had to dremel mine a bit to get it to work correctly.
Just try not to crack the insulation on the bulb return wire (I did)
Old Jan 19, 2010 | 06:02 PM
BumbleBee's Avatar
so did you dremel it so its a huge rectangular hole? cause the way the bulb slides in now there is no way the nubs line up cause the return wire has to go in that smaller hole while the bulb fits through the other.
bump, for the nubs to line up the return wire pretty much has to be facing up, but the wire hole is to the left. sooo lost.
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
yellow dragon
Sep 28, 2015 09:49 PM
SlowSaturn
Sep 28, 2015 11:03 AM
