hid issue
hid issue
i just installed my hid's from vvme they are bi-xenon i got them to come on but i have no high beam i flip the highs on and it does nothing but turn off the fog lights anyone else run into this problem? i am leaving for nc tommorrow night so i kinda need them so i can see.
nah its 9007-3 bi-xenon kit from vvme.com relay and all...when I hit the high beams I can hear what sounds like a clicking noise from the fuse box under the hood. All fuses are in good working order...maybe i will just have to purchase some 9007-2 bulbs so I can pass inspection in NYS
Stock setup. when you push the stalk forward for high beams, the low beams shut off.
You need to put a diode in so that power will be sent from the high beam circuit to the ballast (or relay that operates the ballast) when the high beams are activated.
The diode will not allow power to flow from the low beam circuit to the high beam circuit (assuming it is in the correct direction) so the high beam solenoid on the light will still operate normally.
That being said....hid's in stock housings?
Prepare to get flashed and / or ticketed for blinding people.......
What he said, thats what I was getting at but too damn lazy to type it all out. I had to do this for my wiring harness on my retrofits. And yes, stock housing and HIDs can be bad if aimed incorrectly...Thats why I have Retrofits! To each his own...
Retros FTW. I have a set as well. Just need to wire up for the d2s bulb
ps - where can I get the diode from and what type of diode is it? I'm a little new to this as I'm putting in the lights friday.
Last edited by wantedSS/TC; Aug 25, 2009 at 05:31 PM. Reason: Automerged Doublepost
