high iat2's.... i think
Old Jul 26, 2012 | 09:52 AM
joeyfingers's Avatar
hey guys so i just installed my interceptors last night and im not really sure what normal numbers are or how to tell if my i/c pump needs to be replaced.i live in northern ohio its been super hot and super humid.so normal driving temps are around 120-130 iat2 and the normal iat is around 98-110.i did a few pulls last night night and they jumped to around 160-180 range.i have an 06 ss/sc with the zzp stage 2 h/e and zzp stage 2 kit.any info would be helpful
Old Jul 26, 2012 | 09:58 AM
ssyellow's Avatar
Should be 20 above ambient when you're normally driving. Look in the filler neck to see if theres any flow, not that hard.
Old Jul 26, 2012 | 10:03 AM
CleverOne's Avatar
i see 160 after a hard pull, it should drop pretty fast if your pump is working. Get under your car with a rubber mallet or a hammer and smack the pump housing a few times, also open the filler neck and stick a light screw driver or a piece of long wood turn the car on and see if the screw driver/ wood moves, this will tell you if you have flow or not.
Old Jul 26, 2012 | 10:04 AM
Vander Nars's Avatar
180 is heatsoakin like hell, 1 of 2 thing is wrong either ur not running any cooling mods with ur stage 2 kit or ur pump is dead. U should atleast have a dual pass with that kit, if u do then ur pump is most likely dead.
it gets like 105 here in ga lately and during a second gear pull the highest my ait2 got was 134. Im running gm stage 2 with dual pass and custom tune.
Old Jul 26, 2012 | 10:11 AM
zerosk8ter83's Avatar
check for kinks on the lines make sure there all legit
Old Jul 27, 2012 | 12:27 AM
jcatauro's Avatar
my iat2 are about the same 120-130 but even after a pull they never hit 180 the highest i had was like 160 with the option b tank being really low when its normal 150 is my highest with it being like 90-95 outside
deviance
Nov 24, 2015 05:51 PM
toysareforboys
Nov 17, 2015 05:22 AM
no_ss
Oct 18, 2015 11:58 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Dirtybutwhole
Sep 26, 2015 03:29 PM
