high iat2's.... i think
hey guys so i just installed my interceptors last night and im not really sure what normal numbers are or how to tell if my i/c pump needs to be replaced.i live in northern ohio its been super hot and super humid.so normal driving temps are around 120-130 iat2 and the normal iat is around 98-110.i did a few pulls last night night and they jumped to around 160-180 range.i have an 06 ss/sc with the zzp stage 2 h/e and zzp stage 2 kit.any info would be helpful
i see 160 after a hard pull, it should drop pretty fast if your pump is working. Get under your car with a rubber mallet or a hammer and smack the pump housing a few times, also open the filler neck and stick a light screw driver or a piece of long wood turn the car on and see if the screw driver/ wood moves, this will tell you if you have flow or not.
180 is heatsoakin like hell, 1 of 2 thing is wrong either ur not running any cooling mods with ur stage 2 kit or ur pump is dead. U should atleast have a dual pass with that kit, if u do then ur pump is most likely dead.
it gets like 105 here in ga lately and during a second gear pull the highest my ait2 got was 134. Im running gm stage 2 with dual pass and custom tune.
my iat2 are about the same 120-130 but even after a pull they never hit 180 the highest i had was like 160 with the option b tank being really low when its normal 150 is my highest with it being like 90-95 outside
