High idle/low vac?
Old Oct 10, 2015 | 11:57 PM
High idle/low vac?
Hello all;
So just curious if anyone has had ongoing issues with high idling..
This isnt quite the throttle body high idle where it dips up and down; its more like the car stays in open loop all the time. Runs smooth and like a champ but will not idle below 1300 rpms... Vac gauge stays around 15-16. Boosts full to 20psi.
Wasted a whole can of brake cleaner to find no vac leaks.
New LS4 throttle body.. Idk.
I also tend to keep going through primary 02 sensors; probably another byproduct of my car getting 14 miles per gallon lol.
Anyway idk. Bpv maybe?
Old Oct 11, 2015 | 02:03 AM
tomj77's Avatar
Did u do a tb relearn when u installed it
tomj77's Avatar
Or shall I say throttle position relearn
Old Oct 12, 2015 | 11:17 AM
hmm. not sure what you mean by that. The car was fully tuned for it though.
Old Oct 19, 2015 | 09:04 AM
also i keep going through 02 sensors, might have something to do with why it never seems to leave open loop mode?
are there e85 safe 02 sensors out there?
Old Oct 19, 2015 | 09:22 AM
yellowsupercharged06's Avatar
the e85 shouldnt be the culprit for the o2 sensor. My sensor has been fine on e85, its an OEM one.
Old Oct 19, 2015 | 01:25 PM
Thank you; I must have a frayed wire or something then
Zenkat
Drag Racing
13
Apr 21, 2016 07:06 PM
Jerin
Oct 20, 2015 07:24 AM
reybalt
Oct 12, 2015 08:30 AM
Tupp
Oct 11, 2015 05:53 PM
GreenStang
Oct 8, 2015 03:27 PM
