horn issue
horn issue
so we just finished replacing my clutch and got everything back together, everything worked fine but when i went to start the car soon as the car went to the run key position or if it was started the horn wouls start honking and wouldnt quit. Anybody have this happen?
just dropped sub frame and tranny. Im puzzled because if you turn it to accessory you can honk the horn normally and it stays off, but soon as you go to run position or start it just starts to go off and wont quit. All the things to be and its this, if it was a short I would expect it to keep going off all the time in all positions, maybe Im wrong though
yah its wierd, when i though it was fixed it would be in the run postion or car running and wasnt going, next morning i used my keyfob to unlock the door and it caused it to start going again with the key in the run position, so its like the security system is not recognizing the key fob for some reason.
still having issue, anyone else had this. Im kinda baffled, im ruling out a short because it will be fine after a couple days, i can then put the fuse back in- press the horn normally and it functions fine, but soon as i press the unlock button on the key fob it starts blowing the horn. I know its something to do with the security, might have to get gm to look at this one.
