How to close sunroof with broken switch
Old May 23, 2018 | 04:19 PM
jobocop's Avatar
Unhappy How to close sunroof with broken switch
Hello. My sunroof won't close. Seems like the switch just stopped working. I want to try and close it by unplugging the switch and kind of hot wiring it. Does anyone know which pins to on the female connector to hit to cause it to close?
Old May 23, 2018 | 04:49 PM
Henry3959's Avatar
E to C +
A to D -
Old May 23, 2018 | 04:58 PM
jobocop's Avatar
Thanks for the info. Have to admit i don't really know what i'm done. To confirm, is that two separate wires? one wire from E to C and another seperate wire to A to D?
Old May 23, 2018 | 05:00 PM
Henry3959's Avatar
Yes, unplug all 5
Connect E to C for power
Connect A to D for ground
Old May 23, 2018 | 05:07 PM
jobocop's Avatar
I was thinking of leaving the wires in the connector and using a jumper (wire with ends stripped) and jumping e to c and a to d. I'm assuming that should work as well.
Old May 23, 2018 | 05:08 PM
Henry3959's Avatar
No... do not do that. If your switch is shorted you will start to melt wires.
Did you check your 15amp fuse?
Old May 23, 2018 | 05:27 PM
jobocop's Avatar
No i haven't checked the fuse yet. The sunroof has working on and off for the last week or so. That is why i'm thinking it might be the switch. I might have described it wrong. I have unplugged the switch and am left with the female connector hanging from my roof. Was thinking of jumping it similar to this video
(skip to 3 min mark)
Old May 23, 2018 | 07:02 PM
Henry3959's Avatar
Yes, you can jumper the terminals listed in the bulk connector.
Old May 23, 2018 | 07:47 PM
63 Nova SS's Avatar
Can't you just shove it shut? I hardly ever use mine.
Old May 23, 2018 | 08:08 PM
Henry3959's Avatar
You could shove it shut.... once. It uses the gear and spiral cable mechanism and both sides are in time. I completely removed mine to clean the headliner and clean and re-grease the tracks as well as clean out the drains. You force it and the cables jump out of time.
Old Oct 2, 2020 | 08:37 PM
Jaidyn K. Stubbs's Avatar
Sunroof
Originally Posted by Henry3959
Yes, unplug all 5
do you know the combination to open the sunroof
the jelly man
Oct 26, 2011 08:48 PM
kento19
Aug 16, 2010 12:26 PM
ChiGoku
Dec 22, 2007 12:27 AM
fastss25
Jul 16, 2007 01:28 PM
ajent
Feb 21, 2006 01:25 AM
