How Many Quarts???
Old Nov 14, 2007 | 07:35 PM
cheesetits's Avatar
How Many Quarts???
How many quarts of oil does the LSJ need? I'm going to do it by myself in a bit for the first time but i need to go buy the oil.
Old Nov 14, 2007 | 07:37 PM
kenhebe's Avatar
It ranges from 6 to 6 1/2. Put in 6 quarts. Start the car and let it run for a minute and then check the level on the dipstick. Add if necesary. If you have not changed the oil before on the LSJ though, I will warn you now that it is very tricky to get the filter out.
Old Nov 14, 2007 | 07:38 PM
cheesetits's Avatar
okay... thanks man. You're a life saver.
Old Nov 14, 2007 | 08:16 PM
Pickles's Avatar
It's really not that hard. With decent lighting, the proper socket, and a good long extension for your ratchet, it comes out easy.
Old Nov 14, 2007 | 08:21 PM
randizzle's Avatar
damn i did not realize it holds that much damn oil! that's a ton for a four-banger!
Old Nov 14, 2007 | 08:24 PM
DebadgedBALT77's Avatar
yea like he said, with the proper soket, and an extension it will be a breeze. without that socket its possible but a little more of a bitch.
Old Nov 15, 2007 | 09:53 AM
Coblasts's Avatar
Pull the filter out from under the SC ,There is access there.
Watch you dont damage the wires on the connector with your socket and extension getting at the filter.
The oil filter cap should stay attached,and reattach it to the new filter.
It just clips in.
Also slightly lube the O ring on the filter before installing it.
Torque for the filter cap and drain plug is only 18 ft/lbs
Heres the link to the how to
https://www.cobaltss.net/forums/how-guide-43/oil-change-how-picture-22848/
Old Nov 15, 2007 | 09:56 AM
D4u2s0t's Avatar
it depends how big your hands/arms are
i can barely get my filter out, it's kinda a pain in the ass. but, it's not too bad. better make sure your car is cool though if you value the skin on the top of your hand
Old Nov 15, 2007 | 04:03 PM
buckshot3448's Avatar
yea the filter is definatly a pain in the ass and i put 7 quarts in mine before i reached the right level its ******* insane
Old Nov 18, 2007 | 08:08 AM
Adirondack_Cobalt's Avatar
Everytime my brother changes the oil in my car (he's a GM tech) we go back and forth over the oil... he puts in 6 quarts and it doesn't register 'full'... I drive the car home (12 miles over a mountain) let the car sit, and BAM! "Full"!
rukkee
Feb 28, 2008 01:13 AM
jsscooby
Jun 21, 2007 05:47 PM
bogout
May 30, 2006 06:51 PM
RonSS
Feb 8, 2006 12:48 PM
Florida 76
Oct 17, 2005 01:01 PM
