how to test boost solenoid lsj
Old Apr 7, 2015 | 03:38 PM
The Rookie24's Avatar
ok so after about a hour of looking over my sc because of this no boost problem all gaskets are good the rotors are fine the butterfly valve is good vacuum lines are good new belt and tensioner are good. i zip tied the butter fly valve shut and i got boost with no problems so i know the sc and belt is good i bought a new boost solenoid and tried another actuator but nothing changed.
It would sometimes build no boost or at most 5 psi. is their any way to test the boost solenoid ? I also noticed on the 3 hr drive i just had with the car some times if i would mash the pedal and it would not build boost other times i would get 5 psi instantly and sometimes if i held it while when it wasn't building boost for like 30 second all of sudden the car would have boost to 5psi and you could feel it so I'm thinking that solenoid might be it
any advice on how to check the solenoid or the actuator would be great thanks
Old Nov 21, 2016 | 06:40 PM
mrfitz's Avatar
Did you ever get this fixed?
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
