Humming Sound - Front Driver Side
Old Jan 15, 2013 | 07:43 AM
RozynskiA1's Avatar
Morning,
I have an 06' ss s/c with 112k miles on it and have a strange "humming" sound that gets progressively louder as my speed increases (40+ mph). I'm thinking this is probably the wheel bearing so i took it out to look at it (its definitely shot).
However, just to be sure that it is the only bearing that is shot i had the car jacked up so the front drivers side tire was the only one up in the air. With a buddys help he hopped in the car and threw it in gear (without hitting the gas or brake) and he slowly evened out the clutch to make the bearings spin. The same noise could be heard even with the bad bearing removed making me think its more than just that bearing. Im pretty pissed because now because i think it could be a bearing in my differential Maybe i'm just thinking too much and by replacing the outside bearing it will go away?
Has anyone had an issue similar to this where they had to take apart their differential to solve this "humming" sound?
Any insight is greatly appreciated!
Old Jan 15, 2013 | 07:47 AM
574's Avatar
574
I also have the humming. It's ANNOYING!
Old Jan 15, 2013 | 07:49 AM
RozynskiA1's Avatar
Completely agree - did you look at your wheel bearing?
Old Jan 15, 2013 | 10:44 AM
Sh3itskees's Avatar
Potentially tire noise?
Old Jan 15, 2013 | 10:45 AM
Sox-Fan's Avatar
Got Brakes?
hard to make tire noise with it jacked up off the ground though.
Old Jan 15, 2013 | 02:55 PM
sLAsh's Avatar
Maybe a bad cv joint?
Old Jan 15, 2013 | 02:57 PM
574's Avatar
574
No I haven't yet. My car has 75k on it and I am thinking that might be the problem. No tire noise because they are brand new and the old tires did it too
Old Jan 15, 2013 | 04:09 PM
LS6Rally's Avatar
isn't there a support bearing on the pass side axle on the LSJ's? could it be that.
and wait, were you trying this with the axle and bearing removed?!
Old Jan 15, 2013 | 04:18 PM
CannonBalt's Avatar
It's a wheel bearing. Go down a street with a left and right hand turn. If the noise is coming from the drivers side, and you turn left the noise should stop, and if you turn right it will get louder. That means a bad wheel bearing because you are putting load on and off the bad bearing
Old Jan 15, 2013 | 04:29 PM
574's Avatar
574
What if the car isn't mobile how do you test it
Old Jan 15, 2013 | 04:51 PM
jmesl8er's Avatar
This^^^^^^^, wouldn't the axle be flopping around with no bearing holding it in place?
Old Jan 15, 2013 | 04:58 PM
CannonBalt's Avatar
Humming is a wheel bearing. Just replace it
Solaris99
28
Mar 15, 2017 01:22 PM
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
Tupp
Sep 30, 2015 08:18 PM
