i was down almost 3L of oil
Old Aug 15, 2010 | 11:23 AM
rcmpayne's Avatar
Canada i was down almost 3L of oil
Yea, the wife told me the car was ticking and the TC light was on so this morning i checked it and it only had a bit over a liter of oil however, there is no leaks or spots in the drivway. i havent seen any blue smoke either.
I think it may be time for a compression check. what should i be seeing when i check the 4 cylindars?
Old Aug 15, 2010 | 08:19 PM
scottie's Avatar
only thing I could find on here was 151 psi each cylinder. But that was only from searching the forums.
Old Aug 16, 2010 | 10:52 AM
rcmpayne's Avatar
so i was looking at the car again and my breather (small filter on block) was filled with oil..... is that right?
In case i am not explaning the filter right it was a tube from intake to block before and was replaced with a filter as my CAI had no spot for the tube.
Old Aug 16, 2010 | 10:54 AM
jschatte's Avatar
That should be on the valve cover not the block.
Old Aug 16, 2010 | 10:57 AM
ajm5036's Avatar
I think that's what he ment.
Old Aug 16, 2010 | 03:43 PM
rcmpayne's Avatar
yea, thats what i ment
Old Aug 16, 2010 | 03:51 PM
fredds-turbaltSS's Avatar
do you do your own oil changes? or do you bring it somewhere? so long as all the cylinders PSI are close to each other and hold pressure your good
DarrenGC
Dec 24, 2021 01:55 PM
717ssbalt
Oct 2, 2015 04:01 PM
Trav3480
Oct 1, 2015 08:17 PM
importkiller
Sep 30, 2015 07:18 PM
dennis69
Sep 28, 2015 02:16 PM
