ic pump problem
Old Aug 5, 2012 | 11:31 PM
olmstt30's Avatar
ic pump problem
the pump doesnt turn on but if i crawl under my car and mess with the wires that lead into the pump it kicks on is that the pump its self?
Old Aug 5, 2012 | 11:40 PM
Vander Nars's Avatar
if u just touching the wires and not tapping the pump then it sounds like wires are bad, if ur tapping the pump also then pump is prolly bad as well. Just get some new wires and replace them and see if pump works correct, if it dont then get new pump from ottp/zzp or anywhere else for around 100 to 110 and u should be golden.
Old Aug 5, 2012 | 11:48 PM
nhanson's Avatar
Inspect the wiring. Make sure the plug is seated good. Most likely not the pumps fault.
anotherslowlnf
Sep 29, 2015 03:52 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
