Idling problem
Old Sep 21, 2009 | 12:44 AM
xxxxsh4d0wxxxx's Avatar
Idling problem
-Car will start and sometimes, only has happened twice now, but it will start and die instantly.
-Car idles rough.
-Car gets bad gas mileage. The DIC says otherwise, 32MPG, even after being reset, but it's definitely wrong.
Not sure whats wrong. Plug is fouled? Injector is fucked? Fuel filter is clogged? Butterfly on the TB isn't closing all the way? I have no clue.
The car only has 19,000 miles on it.
The TB is clean. Air filter is clean. MAF is clean.
Old Sep 21, 2009 | 04:37 AM
Coblasts's Avatar
Maf is clean but might be no good !
How does it run otherwise ?
Old Sep 21, 2009 | 05:16 AM
fwdGTP's Avatar
injector maybe? have scans or anything?
Old Sep 21, 2009 | 05:17 AM
Steven Flit's Avatar
Try replacing your EVAP emissions canister located directly to the right of your valve cover.
I had a very similar issue, cept. my car would only idle rough or shut off right after getting gas.
Old Sep 22, 2009 | 12:49 PM
Runs great other than the shitty idle, and the fast that at WOT it feels like a total turd. I mean I know it's a 2.2L, but it used to have a lot more pep.
What do you mean scans? There is no CEL, if that's what you mean?
How much would that cost?
Old Sep 22, 2009 | 03:41 PM
fwdGTP's Avatar
i ment like an HPT log file or something so you could see what's going on with the car.
Old Sep 22, 2009 | 03:42 PM
to be honest I do not know... my friend had a spare one.
Go to your local dealer and ask, or find out the part number and look on gmpartsdirect
Old Sep 23, 2009 | 02:16 AM
I might just bring it in.. I really don't feel like going on a goose hunt, when the car has a warranty.
I'm going to place my money on it having a bad plug or a bad injector.
I would try resetting the computer by unhooking the battery but I was told that doesn't reset it, the Cobalt stores it somewhere in the event the battery is unhooked.
Last edited by xxxxsh4d0wxxxx; Sep 23, 2009 at 02:16 AM. Reason: Automerged Doublepost
Old Sep 29, 2009 | 09:17 PM
RacinJared's Avatar
Hey guys I have a 2006 2.2 chevy cobalt and I am trying to change out my spark plugs but when tryig to twist them out the socket wrench won't budge. I am using all the right tools. Does anyone any tips that could help me on this project?
Old Sep 30, 2009 | 09:04 PM
Coblasts's Avatar
Are you following the Righty tighty lefty loosey Rule ?
If you think they are seized you could spray wd40 on them and let it sit for a while,but from my experience it doesn't really help. Get a bigger Ratchet!!
If they are that tight you might have a issue and they will strip out.
Aluminum likes to stick to steel(The term for it is galling)
Old Oct 5, 2009 | 11:56 PM
RacinJared's Avatar
Spark Plug issues
Yeah I using the lefty loosie righty tighty rule. I will probably have to buy this product that is like wd40 but its stricktly for bolts and things that are really tight and hard to get off. But thanks for the idea though.
Old Nov 29, 2009 | 07:41 PM
a_joyner's Avatar
If you can get your hands on an impact wrench you could try turning the torque all the way down and it might break them loose....gotta be careful though
Old Nov 29, 2010 | 03:02 PM
CelphTitled's Avatar
It could be all those...clean ur airfilter and get new plugs. My buddy had a srt that did this.
Old Nov 29, 2010 | 04:01 PM
b00sted06ss's Avatar
another thread from the dead reborn
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jimbofug007
Oct 2, 2015 12:06 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
