The Infamous Rattle, Neverending!
Old Aug 15, 2008 | 03:15 AM
Ramphex's Avatar
Alright so I checked EVERYTHING, bushings, mounts, control arm bolts, lower frame bolts, heat shields, DP, sway bar links, struts, steering etc... NOTHING is loose or look like it could rattle...
Today I noticed that it doesn't only rattle when I go over bumps at slow speeds but also rattles when I clutch out shifting into gears, powertransfer.. sounds like the mounts doesn't it? From looking at the mounts they look just fine, anything else guys?
Old Aug 15, 2008 | 03:21 AM
theneelster's Avatar
I still think you should take the heat shield off...that's the most common deal with these rattles. You still have stock head/dp right?
Old Aug 15, 2008 | 03:27 AM
Ramphex's Avatar
Yeah, heatshield is on there tight, I can't even budge it with my hand and it has about an inch clearance... I'm thinking maybe it's this..
http://fr33k.5gbfree.com/07-02-35-004.htm
Old Aug 15, 2008 | 07:36 PM
sparhawk's Avatar
i see alot of those with EPS, and 75% of the time its in the coloum
Old Aug 15, 2008 | 08:20 PM
Mr_Slobalt's Avatar
I drove a customer's Cobalt today with an annoying plastic rattle in the steering column...only over bumps at low speeds
this was definitely the steering column rattle no doubt in my mind
funny thing is, is that she isn't complaining about it and it's under warranty...
Old Aug 15, 2008 | 11:14 PM
afireinside7710's Avatar
i take it she brought it in because of that, and if she didnt, that you told her about it
Old Aug 15, 2008 | 11:16 PM
Mr_Slobalt's Avatar
she came in for other problems and I didn't tell her about it
1) the service writer was being a dick to me
and
2) I can get into serious **** if I "upsell" warranty like that
if I could I would be rich off of GM right now.....they recently jumped on our asses about upselling leaks and turning rotors under warranty which can cost our company thousands and possibly more
GM can refuse our warranty work PERMANENTLY and they can also force our company to pay for all the upsold work in the past
Old Aug 15, 2008 | 11:17 PM
ilovecars's Avatar
can you get rid of heat sheilds with no problems? like the one attached to the rear tranny mount. and then the one over the header?
Old Aug 16, 2008 | 01:50 AM
Ramphex's Avatar
Man they said already it's not the heatshield, you don't want to get rid of it because it's there for a reason. Are there any techs on here that have dealt with this steering column problem before and do you guys know if I'll have to get it replaced or there is an easy fix to the current one.
Old Aug 17, 2008 | 04:48 AM
Ramphex's Avatar
Anyone?
jimbofug007
Oct 2, 2015 12:06 PM
brickloaf
Aug 30, 2015 08:59 PM
trent_ky
May 15, 2006 01:27 AM
EverettCobalter
Mar 4, 2006 10:44 AM
