Injen Intake Problem!
Old Feb 25, 2006 | 05:13 PM
silverSS's Avatar
I need to find a direct answer, and yes i serached
ok i installed the injen intake LOVE the whine, but my only issue is the fitment! this thing bulges out my side bumper! WTF!lol how can i get it to not rub against that side bumper??
Is there any fix?
Old Feb 25, 2006 | 05:17 PM
d_backer1's Avatar
I just didn't use the gay ass extension that they included w/it no problems
Old Feb 25, 2006 | 09:44 PM
Nauticabri's Avatar
Is there any fix?
I had the same problem, and now after a few hundred miles I'm getting a CEL with it! HELP!!!! What can I do here? Everyone was claiming the Injen intake didnt cause a CEL but I'm gettin one... What can I do?
Old Feb 25, 2006 | 09:49 PM
d_backer1's Avatar
Just ride out the CEL it will come and go intermittently No biggie won't hurt anything although the light is annoying
Old Feb 25, 2006 | 10:02 PM
Nauticabri's Avatar
How confident are you about that AND how long before it goes out?
Lastly is there anyway to reset the ECU to make it go away without riding it out?
Old Feb 25, 2006 | 10:12 PM
flobeelicious's Avatar
as long as the computer is not reading the too lean code every time the car is running (which is likely the case), the CEL will reset after 3 consecutive run cycles where the code is not thrown. after 40 consecutive clean cycles, it will be erased from the history, as well.
if you just got it after running the intake clean for a while, might not hurt to check to make sure everything is still tight...
Old Feb 25, 2006 | 10:30 PM
Nauticabri's Avatar
I can check to make sure everything is still tight, check the MAF sensor and make sure no issues there as well. I also think Im going to take it up to Autozone to see what code it is spitting to see if its the lean code issue (which isnt anything to be concerned about) or something else that i should be concerned about.
Also I'm DEFINITELY getting the stage 2 kit when that comes out, Do you think they ECU reflash and the larger fuel injectors will stop these lean code CAI issues as well?
Old Feb 26, 2006 | 11:23 AM
Gramps's Avatar
still no CEL for me, I was one of the first to get these intakes. Mine does sit against the fender, but it doesn't cause me any problems. I think you guys might have damaged your sensors, they are really sesitive.
Old Feb 26, 2006 | 08:45 PM
Nauticabri's Avatar
I would be SHOCKED if I damaged the sensor because I barely touched that thing, but I guess how would I be able to be certain at this point?
Old Feb 27, 2006 | 10:25 AM
Nauticabri's Avatar
How frequent is a "run cycle" Meaning basicaly, how often and how long are these cycles so i have an idea of when this damn things should be turning off if all is well...
no_ss
Oct 18, 2015 11:58 PM
717ssbalt
Oct 2, 2015 04:01 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
