Installed AEM digital boost gauge
Old May 19, 2012 | 03:52 AM
Nfamous60's Avatar
Installed the AEM digital boost gauge i used the zzp gauge pillar and tapped into the stock boos gauges red and black wire. the instruction said the blue and white wires were not needed in order to run the gauge, so after the install the gauge does not read boost just has these 2 dash marks on it, i done disconnected it and connected it everywhere just to see if i can get a reading and nuffn, cars still pulls hard and makes boost i just cant see it.
Old May 19, 2012 | 09:02 AM
Omiotek's Avatar
did you hook up the sender properly? i have had sensors be bad right from the beginning. you can test everything with a voltmeter.
Old May 19, 2012 | 01:30 PM
Nfamous60's Avatar
no ill check today it only came with one sensor i didnt use the tiny vacuum line they sent i had a bigger one could that also be the problem? ill post pix later today of my install
Old May 19, 2012 | 02:38 PM
insylem's Avatar
Interceptor
Old May 19, 2012 | 02:43 PM
Mindrot's Avatar
Volt meter
Old May 19, 2012 | 03:15 PM
Omiotek's Avatar
u dont have to use theres but if you can pull the vacumn line off the sensor its too big. u need to ziptie it
Old May 19, 2012 | 05:46 PM
CannonBalt's Avatar
Did you tap into the vacuum line off the BPV? I have the same gauge and have no problems....
Old May 19, 2012 | 08:12 PM
Blowncavy's Avatar
Im thinking this guy just try tapping into wires and didnt use the boost line lol
Old May 19, 2012 | 08:16 PM
bratboy90's Avatar
Just go buy an add-a-fuse and tap it into one of the cars inside fuses. Easy as pie.
Old May 20, 2012 | 01:32 AM
Omiotek's Avatar
did you run the wires for the electronic sender to the back of the gauge? theres 2 different wire harness' one for the sender and one to actually give it power. both need to be installed. check your pins as ive had them come not bent down all the way which gives poor contact and doesnt read and also check the voltage to your sender as ive had them come bad before.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
