Interceptor caught a code!
Old Jan 16, 2009 | 09:11 PM
Mr McCabe's Avatar
I checked my interceptor as I thought it might have been crapping out on my. When I checked the code section of the interceptor it read p0171. I searched on here and there seems to be a lot of information on it but one page reads one thing but another reads a totally different cause...
The car doesn't seem to be working any different then it did before and I'm not getting a CEL on the DIC. Is there any cause for concern or should I just delete it?
Thanks
Old Jan 16, 2009 | 09:18 PM
redline87's Avatar
i believe thats bank 1 lean check to make sure your intake clamps r tight oil cap is down all the way dip stick is down, any false air going into the motor after the maf will cause a lean condition, and im pretty sure the code is lean condition...
Old Jan 16, 2009 | 09:19 PM
Bl4des's Avatar
P0171 System too Lean (Bank 1)
i would look more into it there could be something wrong
Old Jan 16, 2009 | 09:24 PM
Mr McCabe's Avatar
Why would my Aeroforce pick this up and not my car?
Old Jan 16, 2009 | 10:01 PM
Rear-Vue's Avatar
do you have a k/n? if so the oil got into the maf sensor just use some trottle body cleaned and clean out the sensor. i had that code i got it once and read about it on another forum.
Old Jan 16, 2009 | 10:05 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the code is stored on the computer's memory for awhile. sometimes it will stay hidden because it does not happen often or much at all. if your CEL light is not on, dont worry about it too much
Old Jan 16, 2009 | 10:09 PM
stealthy1ss's Avatar
If you are fairly stock with an intake then this is a common code that is thrown. If you are tuned via HPTuners then I would definately look at or redue your tune. You don't want to be the 3rd LSJ that has become a victom of cold winter air this year.
Old Jan 16, 2009 | 10:17 PM
Mr McCabe's Avatar
I only have an injen... and I don't come on to it when its really cold out. I think I'll be fine!
Old Jan 16, 2009 | 10:20 PM
snake890217's Avatar
when I made my intake I had the little breather on the valve cover and it threw that code. I have to have the little tube connected to the intake. Just throwing it in there.
Old Jan 16, 2009 | 10:24 PM
Yeah then you should be okay since you just have an intake. I beleive that there is a service bulletin out for this problem and the dealer will reflash the car for this. I am not 100% sure but I do know that a friend of mine had this problem and the dealer took care of it.
Old Jan 16, 2009 | 10:33 PM
Mr McCabe's Avatar
Ok, good to know. The car is scheduled for service on Tuesday. I'll get them to look at it.
Old Jan 17, 2009 | 11:28 AM
TRANSAM197781's Avatar
check youre filter and all connections on the injen but if it has thrown a light you should be fine
Old Jan 17, 2009 | 11:53 AM
Mr McCabe's Avatar
I've had the injen of over 6 months now...
I was told that the extreme cold may have something to do with it as well... once it warms up I'm going to check my connections, maf, and clear the code.
Old Jan 17, 2009 | 12:06 PM
mine was the same way i went awhile with no code then it started but yes the cold can contribute to it
turbochargedss2012
Sep 20, 2023 12:17 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
nathan112i
Sep 30, 2015 07:12 PM
Extremespeed
Sep 29, 2015 04:34 AM
