Interceptor doesnt power off?
Old Oct 28, 2008 | 02:06 AM
lilhomieb07's Avatar
Just installed my interceptor and i turned the car off and sat there and it didnt turn off so i waited 10min nothing, locked my car came back 15min later still on got inside and i can still go thru the settings and its buzzing like its on when the cars not, anybody help? thanks
Old Oct 28, 2008 | 02:12 AM
Sharkey's Avatar
on the cobalt ss / ion redline you need to run a power wire to the gauge (using the supplied harness) and remove the jumper pin on the back of the gauge. its outlines in the instructions.
Old Oct 28, 2008 | 02:19 AM
ya it powered up with the OBD2 and everything and it turns off when i exit and read all my data but doesnt shut off almost like its still reading data, it sits at the main menu. I might have to add a circuit with additional power wire. Its weird it powers up and everything just doesnt shut off.
Old Oct 28, 2008 | 02:34 AM
Sharkey's Avatar
yea thats the reason why it needs to be powered from accessory 12 volts. the diagnostic port has 12 volts constant, the gauge powers on when it detects communication, but our pcm will stay powered up after the car is shut off.
Old Oct 28, 2008 | 02:41 AM
hmmm i will email aeroforce to make sure, guess ill have to get an add a circuit tommorow then and see how that goes.
Old Oct 28, 2008 | 03:25 PM
Sharkey's Avatar
if you read the instructions on their site is says exactly what i told you and has it specificly noted for cobalt ss and ion redline.
Old Oct 28, 2008 | 03:29 PM
Omega_5's Avatar
Pull the jumper....
Next time, read the manual....
Old Oct 28, 2008 | 04:11 PM
Ya I got ya. I know a lot of guys haven't needed the 12v on there since it says if u don't have full power use the 12v. But I guess in order for my gauge to turn off it will need the accessory fuse and 12v added damnit lol I guess well see what happens tonight when I do that
Old Oct 28, 2008 | 10:15 PM
Well its all good now!! No add a fuse needed went to turn the car off and waited to see if it would stay on and 20 sec later turned off. I noticed it flashes when i open and close my door. Would that be from the sensor on the panel sensing its open so the interceptor acts and a alarm type LED?
Old Oct 28, 2008 | 10:20 PM
BLAZIN07SS's Avatar
I'm too JDM for you
the redlines are powered through the OBDII port unlike the cobalt where you have to run a 12v wire. when you open your door, your ECU is already preparing for you to turn your car on, so it powers the interceptor
Old Oct 28, 2008 | 10:32 PM
Ya i knew something was fishey. LOL ya i was getting gas and i shut the door and the LEDS flashed then i opend it and did it again.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
ernnyyes
Oct 2, 2015 05:16 PM
Stuff
Oct 1, 2015 05:47 PM
nathan112i
Sep 30, 2015 07:12 PM
