Intercooler is Drinking Water
mine was doing the same ****. if you fill it back up and let the car run and it's not bubbling a bit then the pump def went out. i found a place where you can get a good pump:http://www.racetep.com/tneticatolic.html
LaRiche (my local dealer) has no idea what the problem is. I gave it to them on Monday and checked on it today... all they did is test drive it a bunch to try and to get it to repeat itself. >
This evening I took the hose off of the Intercooler pump inlet. At first, I just started the car... no coolant moved... so then I put my hand up against the pump... I felt no suction and no coolant moved... so THEN I kinked the hose and put my hand up against the pump housing... still no suction. Put my finger in the pump to feel the turbine... not moving.
I think LaRiche, just like many other people, don't realize that my intercooler has it's own separate coolant system than the block.
I think I'll try taking it to a different dealer. Maybe I'll see how much I can just buy the stock pump for... something tells me it'll be expensive.
Mine has been eating up coolant/water from the blower fill as well. When it gets low, she runs sluggish and I get random nosing over when tromping on it. I got on it once and went to bang 3rd and she nosed over, sounded like ass, I got off the pedal REAL quick and she just felt sluggish. I opened the hood, noticed the tube was low, threw some water in there, and she drives different afterwards...Same problem??
Dex-cool raises the boiling temp of water ,which I am not 100 % sure that water wetter does, and you are turning the water into steam and it is coming out the over flow and thats why you smell it after a run.I would put the dex col back in and add the water wetter to it.
The water wetter is only to increase the heat absorbing properties of the water and this would make the problem you have happen faster.
Put the Dex-cool back in.
But A pin hole is still possible.
raising boiling temp is going to do nothing for loss IMO.
If you dont see leaks then I could almost guarantee it is the intake intercooler letting fluid but it is still strange since it is under boost and not vacuum when you romp on it. I would have expected it under vacuum when cruising the higway and not under a boost situation.
your not going to get even really close to boiling temp in the intercooler. your running max 160F and typical running is 120F. THe highest I have ever seen is 178F running on a track and making a fourth gear pull running a 2.8 pully on a GM Dual pass system. lol HEAT SOAKED.
You can make water boil at room temp in a vaccum so pressurizing the system has the reverse affect.
Yeah but the previous posts were referring to raising the boiling point. and even if you had air lock or if IC pump not working then there would be alot more issues. besides he is losing coolant on a regular basis.
+Rep to all who even attempted to help.
I can see Dex-Cool being hotter than hell by then.
BUT... if the coolant isn't moving at all... it's just sitting there... and I take off from 35... that ****'s gotta be hotter than hell by the time I hit 4th, right? Because that's right about the time it starts shooting out. Only when I've been on the throttle for a while... usually only when i make it to 4th gear.
The IC coolant system only pressurizes to 5 psi so that only raises the boiling point by 10 or 15 degrees, which would be around 220 - 230 F. The boiling point of dexcool under the same conditions would be around 240 - 260 F.
Talked to the Service Manager at the local dealership... I went into a real technical explanation of what was happening inside my engine bay... to make a long story short, I got him to just go ahead and order me a new pump.
they denied me a new pump because I hit a chunk of tire and bent the condenser and apparently the intercooler (so now it leaks) so I ordered the cobra HE and a Cobra/Lightning Intercooler pump...
did you mess up the heat exhanger or the condenser? I'm pretty sure the actual intercooler is inside the intake manifold... If you messed up the heat exhanger then I could see him calling a no go on a new pump under warranty, but the condenser has nothing to do with the supercharger cooling system.
Hopefully they will have it today... if they don't have time for the install, **** it, I'll do it myself... I miss my boost.
Also, does the Cobra/Lightning pump actually flow, or pump any better than our's does?
not sure...whats the flow rating on our pump? I think the Cobra is rated at 6.3GPM, but I've seen one that flows like 15GPM...that might be a bit much... Should be getting most of the stuff in by next week...I'll let you know what I find out.
Finally fixed. Bitch pulls HARD again! Traction problems again
FTL!
I celebrated by driving around for many hours... and I got 2 kills.
https://www.cobaltss.net/forums//showthread.php?t=79912
