intermediate shaft???
Old Sep 10, 2013 | 07:17 PM
LNFTX's Avatar
I've had a clunk/pop situation going on in the front end for a couple weeks now happens at low speeds when turning the wheel and usually involves the gas pedal
Visually inspected cabs end links and strut mounts couple different times with nothing found and never could duplicate the sound without the vehicle moving
Replaced trailing cabs after finding them partially torn upon removal, felt better but still have the clunk just not as much
Today after rechecking tightness on various control arm bolts, realized I had never tried to duplicate the sound with the engine off and no power steering .turn the wheel right and boom everytime no matter the position of the wheel it will clunk but only to the right, it kinda clicks then stops almost like skipping a gear. Visually inspected the shaft with a person turning the wheel to recreate the sound/feel. Did not see play in shaft but its hard to watch it work under the hood, but you could feel the clunk in your feet and in the wheel car when sitting in the car.
Last thing is when inspecting the intermediate shaft I noticed it looked like the sway bar had been moving side to side in its bushing. The bushing itself look to be in good shape but on each side there was about an eighth of an inch of clean metal showing, leading me to believe that it had been moving side to side and I'm not even sure if this is normal.
So what do you guys think? Intermediate shaft? sway bar bushing/ end links? or should I keep looking elsewhere?
Old Sep 10, 2013 | 07:22 PM
i jsut replaced my intermediate shaft the other day for the same reasons, i was chasing a clunk and click sound. i was led to buy one off of rockauto for $70 and its better quality/thicker than the oem piece. install isn't a walk in the park but its pretty straight forwards and nothing needs to be taken off to get to the shaft. the grommet was the hardest part to do.
My clunk is gone :shrug:
Old Sep 10, 2013 | 07:26 PM
taintedred07's Avatar
Man I've had this same issue mostly after installing my front koni inserts, but me and Japeatr couldn't figure it out. I have the exact same sounds, ect that you're experiencing and I also have a 2010 lnf around 54k. How many miles ya have? I thought mine could be the strut mounts since I put the insterts in, especially being stiffer ect. But I haven't checked the intermediate shaft yet, which I've read isn't properly lubricated from the factory.
Old Sep 10, 2013 | 07:40 PM
LNFTX's Avatar
Almost 81k
I inspected the strut mounts twice once with the car on the ground and once with the car in the air I could find no play or no popping
Old Sep 10, 2013 | 08:05 PM
Cherry GT's Avatar
There is a TSB that tells dealers to "lube and exercise the intermediate shaft"
I tried it, lasted about 2 weeks, lol.
I replaced mine and clunk is gone, but with old shaft in hand you can not feel
any kind of play in any position........I've heard of a few steering collums being replaced.
Old Sep 10, 2013 | 10:00 PM
LNFTX's Avatar
Had steering column replaced under warranty 2 or so years ago different feel and sound links like I'm heading to rock Auto
Old Sep 10, 2013 | 10:12 PM
yea like i said its only seventy bucks and only two bolts holding it in so worth it to try out since you probably do or will need it either way
Old Sep 11, 2013 | 12:59 AM
Thanks for the info, I'll definitely be looking into this
Old Sep 11, 2013 | 01:35 AM
jp1600's Avatar
Taint i already told you that was it! Get under there and move the shaft, youll hear it pop and be able to see play in the shaft.
Old Sep 11, 2013 | 02:06 AM
But I want you to play with the shaft
Old Sep 11, 2013 | 02:11 AM
jp1600's Avatar
Soooooo gaaaaaaaaay! Not that theres anything wrong with that
Old Sep 11, 2013 | 02:40 AM
Lmao
Is there a how to or is it pretty self explanatory
Last edited by taintedred07; Sep 11, 2013 at 02:40 AM. Reason: Automerged Doublepost
Old Sep 11, 2013 | 03:32 AM
jp1600's Avatar
two bolts, hammer and a screwdriver. Very very easy.
Old Sep 11, 2013 | 08:02 PM
LNFTX's Avatar
Bumpskie for any opinions/ideas before I go order intermediate shaft
Turbo Johnny
Feb 21, 2019 09:41 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
medic710
Sep 6, 2015 08:53 PM
