intermediate steering shaft
Old Jul 9, 2018 | 04:30 PM
Johnny Bliss's Avatar
mine started clunking and now it clunks horrible. how hard is it to install one of these? they are $40 on ebay
Old Jul 9, 2018 | 05:10 PM
ProfDNS's Avatar
I plan on doing this myself. This was the best video I could find on how to do it.
Old Jul 9, 2018 | 05:32 PM
Kolt's Avatar
not hard depending on how much rust you have on the gear side joint. Will need a alignment after unless you want to trial and error top joint alignment.
steering shaft.pdf
Old Jul 9, 2018 | 05:34 PM
Why would you need an alignment? The tie rod ends never came off... The shaft on the steering gear has flat spots on it. As long as the steering is straight when you take it off and put it back together the same way there is no need for an alignment.
Old Jul 9, 2018 | 05:38 PM
one 13mm bolt that can be accessed from the drivers wheel well.
Then get under the car with a screw driver or extension and a hammer and beat it off (upward) ahem... lubricant might help here.
Then inside the car, same 13mm bolt and pry the shaft off the column.
Reverse process to install.
I would recommend an oem replacement instead of an "ebay" one. The dorman ones can be found for around $90 on Ebay.
Old Jul 9, 2018 | 05:42 PM
nice,
seems pretty easy expect maybe some hassle under the dash with space constraint.
the clunking is obnoxious and has gotten really bad
Old Jul 9, 2018 | 05:44 PM
https://www.ebay.com/itm/GM-OEM-Stee...wAAOSw8Pda2qjM
https://www.ebay.com/itm/New-Interme...EAAOSwZA1abpn1
Old Jul 9, 2018 | 05:45 PM
if the wheel is locked after the key is out will that be enough to lock the wheel in place when the shaft is removed?
Old Jul 9, 2018 | 05:48 PM
Its kinda hard to get the wheel to lock in the correct orientation for removing the bolt. I would suggest removing the bolts and then locking the wheel if that makes you more comfortable.
Old Jul 9, 2018 | 06:32 PM
Kolt's Avatar
you don't have to as long as you can get it back lined up since the top joint to the column doesn't have a set location like the gear does. ive had to move a spline or two before to get it just right and have had some that just would not line up.
Old Jul 9, 2018 | 07:52 PM
63 Nova SS's Avatar
I agree on the doorman unit. Unless you want to chance having to do it again. The doorman shaft is also a upgraded unit. Install is how others have said. Factory ones can be froze in there pretty tight. I never seized mine when putting it back together and have had it off since with little effort.
Don't wait too long, I actually broke one that was getting sloppy, and you lose your steering when that happens!
Old Jul 9, 2018 | 07:55 PM
haha i was wondering i bought a new one will be here in a week or so
Old Jul 10, 2018 | 06:10 AM
63 Nova SS's Avatar
Thankfully when I lost one in my Cherokee I was at a stoplight trying to turn, and it didn't. Blew the clock spring assembly also. Went home and checked my truck and 1 of the bearing cups was rotted off of it too so it was on its way out.
Old Jul 10, 2018 | 08:06 AM
royce777's Avatar
its your steering column
Old Jul 10, 2018 | 09:29 AM
werent you working on an upgrade for these? I remember you swapping something to make it tighter.
Old Jul 10, 2018 | 09:59 AM
royce777's Avatar
yes, its been pushed off. I have access to injection molding business so I gotta figure out which is gonna be a the best route. Harder plastic or a metal gear.
Old Jul 10, 2018 | 10:33 AM
Do you have pictures on how to take one apart? Id like to visualize where the play is.
Old Jul 11, 2018 | 07:58 AM
jdbaugh1's Avatar
First time I separated my shaft from the steering rack I had a hell of a time getting it to break loose. A lot of cussing and questioning if I was actually doing it right.
Old Jul 11, 2018 | 09:51 AM
Kolt's Avatar
Skip the part about taking the pivot bolt out and take the snap ring off with the lower column in the car. Once the torque sensor is out you can see the motor and shaft gears. If you decide to take it apart I recc lifting the front end and be cautious with the sensor, it breaks easily and if it has to be replaced it has to be recalibrated very specifically using a tech 2.
Column.pdf
Old Jul 14, 2018 | 12:08 PM
T-Man's Avatar
For the record, I replaced my failed OE with a Dorman unit and it's the biggest piece of ****. It's not been but maybe 5-6K miles and it's failing already.
Old Jul 14, 2018 | 07:28 PM
63 Nova SS's Avatar
Seriously? That sucks, mine has probably got 10k miles on it. Maybe I should take a look at it. Steering still feels tight.
Old Jul 16, 2018 | 05:39 PM
well i went to do this today and right when i took the wheel off i could see that the sway bar end links i put on, the nut backed off. i put some blue loctite on it and its back to normal so i'll just put the steering shaft on the shelf.
Old Jul 17, 2018 | 03:24 PM
63 Nova SS's Avatar
At least you found it. That's nice
Old Jul 17, 2018 | 04:33 PM
i should've checked before i bought it but i dont have time to do much and it'll probably need it eventually i plan on keeping the car for a long time as a driver. it gets driven a lot everyday
Old Jul 17, 2018 | 05:47 PM
califcarm's Avatar
Glad you found the problem. I changed my sway bar end links. Still clunk. Changed my intermediate shaft still slight clunk. Down to steering column, or the rack itself.
I saw a video of someone putting a wrench right on the input shaft to the rack and and move it back and forth and could identify the clunk. Wish I would have done that to know if it is the column or rack. I think mine is the rack as it does not sound like it is from inside the cabin at all. I even checked the sway bar bushings and those look good and solid.
chris88z24
Sep 14, 2017 04:33 PM
Mendomar06
Dec 12, 2013 11:20 PM
yogs10
May 8, 2011 11:27 AM
bigmd
Jun 12, 2010 12:46 PM
CoolCobalt_NY
May 17, 2006 10:00 PM
