Jerking in 1st gear
Old Mar 19, 2008 | 02:46 PM
rukkee's Avatar
Originally Posted by invisible
Then you need to learn how to drive your damn car.
HaHA ... whatever , i've experienced the same issue and the only way to make it smooth is to (IMHO) abuse the clutch. It's mostly a motor mount issue , the TD helps.
Old Mar 19, 2008 | 02:47 PM
bridfi's Avatar
Originally Posted by ptrblkz24
If im driving through a parking lot at like 5mph nice and smoothly and slow down for some reason,when i give it gas again the whole car starts bucking and jerking back and forth.It gets to the point where its so bad,it looks like your just learing how to drive stick.Sometimes im too embarassed to even drive through a parking lot.
ohhhh i understand what you guys are talking about now... first is a very touchy ratio... if i'm in a parking lot, going anywhere from .1 mph - 15 mph, i put it in second. first isnt really a driving gear. its just used when your at a DEAD stop. if you are rolling AT ALL, put it in second. thats what i do and i dont get this prob. the only thing is with putting it in second, is you dont get as much "throw you back in your seat feeling" (and i have polurethane mounts so it vibrates like no other), if you want to do that, put it in first, and rev high, release clutch faster than normal... i mean, thats what i do.
although, if you ARE in first, just be eeeasy on the gas, like your playing with a baby or something... and it shouldnt buck that hard. but all manuals do this. just some do it worse than others because like someone else said, more/less torque, or higher/lower ratios...
Old Mar 19, 2008 | 04:01 PM
ptrblkz24's Avatar
Yeah,i need to learn to drive my car.Why didnt i think of that.Its a known complaint with these cars dip ****.This is coming from someone saying its because first gear is so damn torquey,LOL.You dont deal with stop in go traffic like i do in nyc.You live in the friggen desert,all u have to do is make sure u dont hit a cactus.So,go back and read ur magazines of super street and pretend like you know something about cars.
Old Mar 19, 2008 | 04:07 PM
chris88z24's Avatar
lmaooo
It's the drive by wire. The lagginess and sensitivity of the pedal causes it to do that. The soft stock mounts don't help this either.
Old Mar 19, 2008 | 04:29 PM
thefictionwelive's Avatar
First gear doesn't like you to stay slow on it, I only get the problem when I have to creep through first to avoid bottoming out on something.
Old Mar 19, 2008 | 04:56 PM
maverick0716's Avatar
It's not just with these cars. It has more to do with the transmission's 1st gear ratio being so high (numerically). My Mustang GT was even worse than my G5 GT.......it's to do with the ratio, not the car.
Old Mar 19, 2008 | 04:59 PM
Misery5567's Avatar
I when I read "all u have to do is make sure u dont hit a cactus"
Old Mar 19, 2008 | 05:19 PM
SS-Balt's Avatar
clean out ur throttle body.
Old Mar 19, 2008 | 05:26 PM
rrutter81's Avatar
Originally Posted by MarcS
More clutch, less gas when you start out.
^wins^^^^
if you start jerking a little push in the clutch a little and let it re-seat.
Old Mar 19, 2008 | 05:28 PM
halfj99's Avatar
jesus christ put it back in your pants and atleast wait til your in 3rd gear to start jerkin it
Old Mar 19, 2008 | 07:34 PM
  #36
rukkee's Avatar
Originally Posted by rrutter81
^wins^^^^
well no **** lol . Anyone can make it stop by pushing in the clutch , but why does it start in the first place.
Old Mar 19, 2008 | 08:11 PM
  #37
rrutter81's Avatar
thats like asking me why your paint scratches when you use sand paper.....
in short:
operator error
Also if i remember correctly 1st gear doesnt have limited slip, but that only helps with grip so ur SOL
Old Mar 20, 2008 | 02:28 PM
  #38
rukkee's Avatar
in short:
operator error
WTF are you talking about ? operator error?
First gear doesn't have limited slip lol?
Old Aug 3, 2008 | 02:29 AM
  #39
SSnAZ's Avatar
I get the same rocking and bucking feeling in a parking lot that everyone else is talking about. I have huge ass speed bumps so when i go over them my car bounces, and that leads to my foot rocking EVER so slightly on the accelerator causing it to CONTINUE to buck and get worse. SO i have learned that lesson. Secondly, on my car in first gear, if i am at.... say 2000 RPM and i let off the pedal completely, the second the car hits about 1200 RPM the tach starts to bounce off 1200 and 1000 RPM and it will buck by itself..... motor mounts? dirty TB? Gear ratio? help!
Old Aug 3, 2008 | 02:38 AM
  #40
ls1fbody's Avatar
Haz l33t wheelz.
SOFT MOTOR MOUNTS, plus large amounts of torque, short gear, touchy throttle, it's all been said. get some solid motor mounts, and stay out of first as much as possible.
Old Aug 3, 2008 | 03:34 AM
  #41
SSnAZ's Avatar
ya but i dont want super hard shaking coming from my engine. I have Poly mounts in my eclipse and they shake like a mother ******. My whole steering wheel vibrates on idle and start up, and u dont even wanna know about the AC compressor lol
Old Aug 3, 2008 | 03:55 AM
  #42
D4u2s0t's Avatar
^wins^^^^
it's amazing how many people don't know how to drive their car. what you guys are doing is burning your clutch. yea, it solves the jerking problem. but it's burning your clutch, and not the way to do it.
the trick is to just be very steady in first. the proper way to start from a stop is to let the clutch up to the engage piont, THEN hit the gas. you don't hit the gas, and slowly let up the clutch. that's the wrong way to do it, and it will only cause clutch problems down the road.
another rule is that you ONLY use first to get to second. what the above person said is wrong. do NOT push the clutch to let 1st "reseat". that's bad on your clutch, and it's bad on your synchros. if that doesn't make sense, you want to be in first gear as little as possible. get going a little bit and shift into 2nd unless you're racing. if you're in first, let off the gas, and get bak on it, it will most certainly be jerking. instead of letting off and getting back on it in first, shift to 2nd. problem solved.
Old Aug 3, 2008 | 08:36 AM
  #43
Blue_Balt's Avatar
Apply the gas gingerly and let off it gingerly.
The jerk in first gear is normal.
You don't need much gas at all to get the car going. I literally give the engine enough revs just to to keep near idle to get the car going(Of course hit the clutch engagement point first).
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
brett.higgins3
Sep 24, 2015 09:51 AM
