Jump it the Check Engine appered
Old Feb 12, 2007 | 01:17 PM
lightningfast5's Avatar
Saturday night i had to jump my car cause the battery was dead. When i jumped it the check engine light came on. Ran it to Auto Zone real quick and it came out P2610 which is something with the internal time, i belive thats what he said. Im taking it in tomorrow to get look at.
Old Feb 12, 2007 | 01:26 PM
DarkSergeant's Avatar
What caused your battery to die? Chances are whatever did that (unless it was leaving your lights on somehow) was probably what caused the CEL.
Other than that i'd assume it's either a coincidence or due to your ecu being reset and causing it to throw an old CEL that had been turned off?
Old Feb 12, 2007 | 01:30 PM
Im not sure myself but when we connected the cables and i tried to start it there was a weird pop noise from under the hood. and then my dash became a christmas tree with all the lights flashing. And then everything shut off. The remote wouldnt work, nothing at all would happen if i tried starting it. So we took the cables of for a bit then put them back on and then it started up and the cel came on
Old Feb 12, 2007 | 01:33 PM
dervin3's Avatar
I left my lights on one time and ran mine down. After I got a jump a cel was on. Just something to do with PCM KAM(Keep alive memory). Basically the PCM forgot something and it's safe to just erase it. Can't remember the code but it does it everytime the battery is disconnected or ran dead.
Old Feb 12, 2007 | 03:02 PM
ok but i took it to auto zone and he said it was a P2610, having to do with the internal timer
Old Feb 12, 2007 | 03:08 PM
blacksssc05's Avatar
hmm thats weird
Old Feb 12, 2007 | 03:11 PM
Coblasts's Avatar
Hope that pop you heard wasnt the diodes in the alternator, which could happen if the cables touch while connected to your car.
Old Feb 12, 2007 | 04:44 PM
If it's under warranty, take it to the dealer with the "omg, this thing is a piece of junk, idk what's wrong with it" story.
Old Feb 13, 2007 | 06:12 PM
Just talked to the dealer. The computer is fryed. They ordered a new 1 from Chicago but cause of this beautiful Wisconsin weather it wont be here till Thursday
turbochargedss2012
Sep 20, 2023 12:17 PM
brandon04
Oct 21, 2015 07:04 AM
HEATON
Oct 16, 2015 07:21 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
