just installed intake. HELP!!!
i just installed my injen SRI. sounds great btw but my speedometer does not light up anymore. i thought i had heard of this happening before but i couldn't find it in the search. can someone please help?
You checked all the connectors around the area you were working.
I cant see how the install of the intake could have anything to do with the speedo lights not working.
Stupid question but could your dimmer be turned the wrong way.
Only a few thing can cause them not to work.
Bad wiring to the light.
BCM gone bad
Bad connection to BCM
Day light sensing unit gone bad
Dimmer switch failed(Im leaning towards this one)
BCM gone bad
i fixed it. thanks for all the help.
turns out there was a short in the headlight wiring harness from when i still had the gen 1 projectors.
a little electrical tape and a new parking lamp fuse did the trick.
thanks guys.
thanks guys.
Delta coupe
Sep 30, 2015 08:11 AM
OrangeCoba
Sep 25, 2015 06:06 PM
